Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the
steering column, next to the emergency brake pedal. You need to remove
the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
15A
Lt. Blue
Stop Lamps, Hazard Warning Lamps, Speed Control,
Cornering Lamp Relays
6A - CB
Windshield Wiper/Washer Pump
Spare - Not Used
15A
Lt. Blue
Taillamps, Parking Lamps, Side Marker Lamps,
Instrument Cluster Illumination, License Lamps, A/C and Heater
Illumination, Radio Illumination, Digital Clock Illumination, Autolamp
Relay
5
15A
Lt. Blue
Turn Signal Lamps, Electronic Day/Night Mirror,
Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless
Entry, Cornering Lamps
6
20A
Yellow
Rear Defrost Timer, Chime, Back-Up Lamps, Cornering
Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display,
Illuminated Entry, Anti-Theft Module, Turbo Buzzer
7
15A
Lt. Blue
Fog Lamps (Turbo Only)
8
15A
Lt. Blue
Courtesy Lamps, Key Warning Buzzer, Illuminated
Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster
Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft
Relay
9
30A
Lt. Green
A/C Heater Blower Motor
10
20A - CB
Horn, Cigar Lighter, Fuel Filler Door,
Flash-to-Pass, Speed Control
11
20A
Yellow
Radio, Tape Player, Premium Sound Amp, Power
Antenna, Graphic Equalizer
12
20A - CB
Power Seats, Power Locks, Keyless Entry
13
5A
Tan
Instrument Cluster Illumination, Radio, Climate
Control
14
20A - CB
Power Windows, Power Moonroof
15
10A
Red
Taillamps, Rear Side Markers, License Lamps,
Electoluminescent Coach Lamps
16
4A
Yellow
Electronic ATC
17
15A
Lt. Blue
Electronic Cluster, Tripminder Display, Fuel Gauge
(non-electronic cluster), A/C Clutch, Speed Control Module, Graphic
Warning Display Module, Electronic Blower Speed Controller
18
10A
Red
Warning Indicator Lamps, Autolamp System, Throttle
Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer
Fluid Level Indicator
