Question about Acer America Acer Aspire AX1301-U9032 Desktop PC Windows 7 Home Premium 64-bit
Pc wont boot from dvd drive or harddrive port 1 error help
Posted by mark markland on
Jose Diaz
  • 2,878 Answers
I'm not sure what that error means, but the first drive is usually drive 0 on computers. Maybe this will help. You can verify in BIOS. gl
Posted on May 31, 2013
Pc
start pc press F2 or Delete enter Bios, check boot priority is dvd-rw od hdd set to suit, change ide/sata cable to hdd they do burn out... make sure sata 1 hdd / or ide 1 master, for C drive. hope this helps. I/O errors can occur usually swapping order of boot can fix this...
May 30, 2013 | Acer Aspire Computers & Internet
Setting of USB boot
http://support.fujitsupc.com/CS/Portal/supportsearch.do
A6110/A6120 BIOS Guide
Boot Menu
Nope. No option for booting from USB
1. Floppy Disk Drive
2. Drive0: (Harddrive)
3) CD/DVD Drive
4) NETWORK
5.
6.
7.
Excluded from Boot Order:
USB MEMORY
USB Harddrive
Back before USB thumbdrives (Flash Drive, whatever), came on the scene; the Floppy Drive was used. Then the Optical Drive came out.
(CD/DVD drive)
Transfer the boot data to floppy disks, or a CD/DVD disk.
Make sure they are bootable..........
Regards,
joecoolvette
May 06, 2013 | Computers & Internet
A770E3 MOTHERBOARD 4 GIG RAM SATA 1 TERABYTE HD SATA CD/DVD NETBIOS SEE EVERYTHING FINE. BOOT SEQUENCE FOR CD ROM 1ST PROBLEM. WONT BOOT ANY OS. XP PRO ORIGINAL DISK LINUX UBUNTU...
You can get a manual here:
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=450
Did you set the boot sequense in your bios ??
First your CD or DVD drive
Second you harddrive.
Harddrive must be in sata 0.
CD or DVD must be in sata 1.
Or look in the manual how the settings should be.
Good luck.
Feb 27, 2011 | Biostar A770E3 AM3 AMD 770 ATX AMD...
Cant start my laptop it reads "reboot and select proper boot device and the screen is black ?
Go in to bios by pressing del key sometimes F2 or F1 and see if your harddrive is set to 2nd highest boot priority.Set your CD/DVD drive to first. Save your settings and exit. Remove any cd's/dvd's you may have in your drive plus if you have a flash drive plugged into the usb port unplug it before starting.
If you still have this problem, your harddrive might have a problem with the booting files on it. Reinstalling or repairing windows will fix this. Put your windows disc in and boot to it.
Hopefully you wont have a problem installing or repairing windows or your harddrive could be bad. Before buying a new harddrive for it try removing it from the bay and reinstalling it, in case of a bad connection (example:harddrive wasn't fully connected.).You could go into bios and see if it shows up there.
Hope this helps ya.
Jan 10, 2011 | Computers & Internet
I get disk read error when I try to boot it up.
hi there, here are possible solutions to your issue
1. make sure first that your computer would be able to identify your harddrive. you can check this one by going to the setup utility page. upon pushing the power button quickly tap the F1 key or F2 key. then check your Harddrive if motherboard was able to detect it.
2. make sure that there is now usb flash drive or external drive attached to your usb ports when booting up your computer. sometimes if you have this devices attached to your usb this error happens when booting up.
3. Power on the computer and keep on tapping F8 key the moment you push the power button. select safe mode once oyu enter the black screen. if same error occured. then, ou need to use the recovery disk that came with the system and restore the computer back to original factory settings.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 07, 2010 | IBM ThinkPad 600E 2645 Notebook
0xc000000f error, Laptop wont boot into vista, tryed vista dvd to try recovery but wont load
That error maybe a harddrive faulty / not connected. But you may need to go into the setup/bios and change the boot order so that it boots from CD first To get into the bios when the PC boots you should see a message on the screen for a very short while which will tell you how to get into the setup/bios - usually by pressing a key - like F2, or DEL key or F10 once in the bios you then need to go through the menus at the top until you find a menu page which includes the boot order - make sure CD is first
Another test, if you have access to another PC and CD writer, would be to create a bootable CD from ubuntu - this will boot from the CD only and test that the hardware works
goto http://www.ubuntu.com/ and download the ISO
full details are here http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-your-dead-windows-computer/
click on the image "download ubuntu"
Select a location
then begin download
Save the file onto your PC – remember where you saved it – so you can find it again to create the image bootable CD.
You do NOT copy the ISO file onto a CD - you have to use the ISO to create a bootable CD The CD creator software you have on the PC may have an option to create an image from an ISO If not - use this free program http://www.imgburn.com/
When the UBUNTU CD boots - you will see the following options 1) Try ubunto without any change to your computer 2) Install ubuntu 3) Check CD for defects 4) Test memory 5) Boot from first hard disk.
Use OPTION 1 "Try ubunto without any change to your computer" ONLY this option this will run from the CD and not install onto your harddrive - be careful, if you do install onto the PC - you will wipe the data and software OFF your hard drive.., so repeat only use option 1
Now you should see a UBUNTU desktop This at least proves the main parts of the PC are working
With UBUNTU it may just be possible to copy any of your data onto a USB harddrive or thumbdrive
Feb 27, 2010 | Toshiba Satellite Pro P300 Notebook
I am getting an error message when booting PXE-E61
The hard drive is most likely failing. It is being detected but is not functioning (when a boot device isn't seen or fails to boot, the system trys to boot to network and that causes the PXE error.
Most likely, since the drive detects, but doesn't work, replace the HDD
Jan 26, 2009 | Computers & Internet
XWT-RC061 SATA card used for DVD rewriter wants to boot computer.
from the manual
Note: there are 2 sata drive ports and 1 esata port named P1 to P3. (P1 and P2 are internal) Chaning the jumper setting allows you to select between external and internal ports to use.
Both underside --> P1 and [email protected] are working
Both topside --> P2 and P3 are working
hope that helps...
Jan 24, 2009 | Fanner (XWT-RC061) ATA Controller
Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Sep 21, 2008 | Computers & Internet
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Acer America Acer Aspire AX1301-U9032 Desktop PC Windows 7 Home Premium 64-bit Logo
224 people viewed this question
Top Acer America Computers & Internet Experts
JonSnell Electronic
JonSnell Electronic
NOEL
NOEL
Are you an Acer America Computer and Internet Expert? Answer questions, earn points and help others
