Model no KTES8
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Excellent writeup. Fixed it in 1/2 an hour. Thanks.
You've given me hope...though I'm a little uncertain about the shorted diode. Will this involve soldering in a replacement?
Yes Wendy, soldering is required. Any electronics technician can easily do this.
I have exactly the same problem. I tried to take apart, but the wrap-around cover seems impossible to remove. There must be some kind of trick to disassemble. Anyone know how?
the wrap-around cover seems impossible to remove. Here must
