I have a cuisinart brew central 12 cup DCC-1200W coffee maker. I can program the brew timer, but my clock will not allow me to set the hour or minutes. I turn the dial to the "clock" position, then press the hour and minute buttons and nothing happens. But, if I turn the dial to "PROG" to set the brew time, the hour and minute buttons work just fine. I'm frustrated. Setting the clock time used to work, but we had a power outage and I am not sure if that messed with the clock's function. The clock does not tell accurate time, so I have to compute when the brew should turn on for it to brew at the desired real time. (hope that makes sense.) Any ideas on how to fix it??? Each time we have a power outage, it's even more frustrating to set the brew time when the clock can't get set.
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
