Hi can you tell me will a mincer for A901 mixer for my KM300 mixer please thanks
1) remove the front power outlet of the mixer head.
2) look for a notch in either the top edge or the bottom edge of the casting. (hole)
3) Guide Pin on 9xx accessories is at the top of the connecting shaft.
4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
SOURCE: Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
SOURCE: kenwood A901
Contact a locale store that selling kenwwod and ask for a splashguard, the spare part number is KW604349 it´s a 'D' shape
SOURCE: kenwood mixmaster spare parts
Hello you need a complete mincer, or a mincer part ?
try in 4kenwood.co.uk ( be careful )
or in Ebay.co.uk
Billingtonelec.co.uk
regards
Kenwood Chef Restore
SOURCE: Kenwood Mixer A901 dripping gearbox oil through
the seal is in the middle of the bearing take gearbox to piece (not easy) and remove with bent sharp needle
SOURCE: What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
