Question about Delphi SKYFi3 XM Radio Receiver
Powering up Delphi SkyFi 3
When i start up my SkyFi 3, IT only gets as far as the "Detecting SD Card." Even with a card in the reciever, it still does not detect it and does not move past that screen. Rebooting with the ModeButton and Volume up only brings me to the same screen and no farther.
Posted by mdrysdale on
  • 4 more comments
  • Anonymous Mar 24, 2009
    I had this problem. I called Delphi and they replaced the unit. Nothing could be done from my end. I tried upgrading the firmware and still nothing.
  • Anonymous Apr 04, 2009
    Same thing out of the blue. Card in slot or not, still a dead end. Volume up and Mode switch held does not help either. I will have to check on my warranty, I know it has been over a year. Typical technology!
    Somebody please find a way to resolve this.
  • Anonymous Apr 08, 2009
    My Delphi Skyfi 3 boots up to "Scanning Media ,'' and no further. I pulled it out of the cradle in my truck and took it into work to play, and it's never booted up again.
    rod
  • Anonymous Apr 09, 2009
    I was recording a channel on the way to work. I took the Skyfi 3 from it's cradle and took it into work. Later I booted it up to listen... and it will not go past the scanning media screen. Is there no combination of buttons to push to reset it?
    Rodney in Tennessee
  • united9198 Apr 21, 2009
    I am now on my second SkyFi 3 and the freeze while "Checking For Media" problem continues. I have done everything requested by Delphi including sending my unit in for repair. The unit that I got back has the exact same problem.
    I called Delphi and was told that this is a problem with this radio and they will replace it if I send it in. They told me that they did not have a fix for the problem other than trying another radio. When I asked if the replacement would have the same problem, I was told that would be known until I installed it in my car and activated the new radio with XM.
    Between billing hassles with XM and equipment hassles with Delphi, I am about one inch from ****-canning the whole issue and going back to listening to my iPod. Do you suppose there is any chance that Apple will buy XM Sirius and Delphi and do the job right?
  • united9198 May 15, 2009
    After continued problems with the SkyFi 3 hanging at the "checking media" screen I called Delphi again. Once again, I got 20 minutes of hold, but after getting through, I may have found the solution.
    The Delphi rep instructed me to REMOVE THE RADIO FROM THE DOCK and do the reset. (hold down right arrow button while pressing the off-on switch. On at least 5 previous calls, I was never told to remove the radio from the dock when doing the reset. The tech rep said that is the solution and that I should have been told that previously.
    No one mentioned that bit of information and since it has now been 3 days since the reset, it appears to have fixed the problem. Who would have thought it would be so simple.
Anonymous
I found the soloution to my problem on the "Shop Delphi" website. I had to do a hard reset described at this link:
http://www.shopdelphi.com/contact/ce/s_pf/#2516
It erased all memory in the Skifi and reset everything back to factory specs, but I have my radio back.
Rod in Tennessee
Posted on Apr 21, 2009
Anonymous
I called Delphi today and reported that my Skyfi3 had died. They told me to
- put the radio back in the charger and then
- press the + volume and mode button together for 3 second to reset the radio
and it worked. Now the radio is charging. I'll see what happens once it's fully charged.
Posted on Apr 20, 2009
Gil Davis
    Novelist:
    Scholar:
  • 157 Answers
I've found that if the radio is very cold, it won't reset no matter what you do. I place it in front of a heater vent to warm it up for a while and it makes it work properly after the reset is done. Now, I don't know if it will work in your case, but it's worth a try. I'm going back to my original Delphi XM2GO radio...never had any problems with that. I'll use the SkyFi3 as an oversized MP3 player.
Posted on Apr 06, 2009
Anonymous
I was able to get past the scanning SD and Checking media freezes. What I do in the car is put the radio into the cradle just far enough to get it power, then when it passes the first screen (past the version check at the bottom), and pulls up the MP3 song playing, I push it all the way in. Then, I cycle through the modes to get a clear broadcast through the FM modulator. Some times, the MP3 song takes about 10 seconds to come back up if you go back to this mode, but it eventually plays. A pain in the neck to do some times, but it works.
Posted on May 15, 2009
My skyfi3 is frozen on detecting sd card
Push VOL UP and PWR at the same time to RESET the radio.
Upload the latest firmware from ONLINE spot via Mini USB cable. Call Delphi on the phone for more info and details on how to get thiis unit to work better without locking-up as much..
Sep 06, 2010 | Delphi SKYFi3 XM Radio Receiver
Powers up but locks up on "detectin sd card" screen
A very common problem on the SkyFi3! Press the volume UP and the Power button at the same time and it will finally go off. Go to the Delphi/XM website and upload/download the latest FIRMWARE and upgrade it. Then, call the 800 phone number for Delphi and they will tell you a secret master reset you have to do once or twice, and it will cut down the number of lockups during checking media by quite a bit. Also, do not use a Micro SD card larger than 2MB as well. Good luck, and let me know how it goes for you.
Jul 29, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
When I turn on my skyfi3 it goes to detecting sd card and lockes up from that point on
Press and hold volume up and power button at the same time to do a reset and to power down. You need to update firmware from the XM website to your unit and then do a master reset. contact Delphi by phone for deatailss lon how to reset and update firmware. Do not use a card larger than 2GB either.
Dec 28, 2009 | Delphi SKYFi3 XM Radio Receiver
Locked on Detecting SD Card
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 13, 2009 | Delphi SKYFi3 XM Radio Receiver
My unit starts up and just says at top "Checking Media" can not use any buttons, just frozen!
Take the sd card out, reboot by holding volume up and menu at the same time for 5 secs, wait for it to fully boot into the music, then put the sd card back in.
Oct 26, 2009 | Delphi SKYFi3 XM Radio Receiver
My SkyFi R 1.18 does the same thing but the solution here doesn't
If it freezes, you have to push the volume UP button and Power button to 'reset' the unit.
go to the XM website and get the latest FIRMWARE update for the SkyFi3 and download that. Also, you CANNOT use an SD card larger than 2GB or you'll have problems too. So first, upload the new firmware (using the AC adapter plugged directly into the bottom of the radio) and the cable that they gave you to hook up to your computer and do the firmware update. Delphi customer service can walk you through this too. Good luck, you'll get it pretty soon.
Aug 08, 2009 | Delphi SKYFi3 XM Radio Receiver
New route
From Delphi tech support:
NAV200 SD Card Reformat
Problem:
Customer reports that the NAV200 has lost its voice prompts and/or constantly reads NEW ROUTE.
Solution:
Reformat SD card from FAT-32 to FAT. And replace files on SD card with back up files from DVD-ROM.
Reason for Problem:
The navlib.ini file located in the navigation files (in mnav) is missing from the SD card. It is located in mnav in the back up files found on the DVD-ROM
Jun 19, 2008 | Delphi NAV200 GPS Receiver
Skyfi won't turn on
if you're radio won't turn on....there are only 2 things that u need to do..first is to have the battery replaced, if it doesn't you just have to call the manufacturer/have it replaced if it has warranty...if u guys wanna save time dealing with it..
May 30, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Trying to update firmward on Delphi SKYFi3.
when it gets stuck scanning. Press (volume up) and the (mode) button both down for a few seconds. when you release the two buttons this will turn it off and back on in few seconds.
Mar 20, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Receiver Logo
1,996 people viewed this question
Top Delphi Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Eric Rotmil
Eric Rotmil
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
