Windows 7 Removed and re-installed drivers Changed colour profiles Tried printing across network from other computer
SOURCE: connected ir3300 to network. Can ping static ip
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
SOURCE: Canon Pixma ip1000 does not print Grayscale and other colours
I have lost the printer driver of Canon PIXMA iP1000, would you please assist me to dowload the driver free.
regards, Anup
SOURCE: canon ip1000 not printing even after replacing a new ink catridge
This might seem a dumb answer, but have you removed the PULL tab over the breathing hole. I had a similar problem until I realised my error.
I want print but my printer pixma 1000 say error 5200, what the meaning it ? I lost my manual instruction book. tq
