Connection of 6 computers to use one printer - Computers & Internet
Posted by Sicebi Mntu Mtiyane on
Jose Diaz
  • 2,878 Answers
A network printer can have many more connections. Most people have a wireless router that allow the whole household to use. The printer must have a unique IP address that was assigned by the router. From there the computer simply pints to that resource (IP via network cable) once it has been installed on each computer or device. Think of like a office setup.
Windows also allows for attached printers to be shared if the printer is not networked directly to the router (USB connected to PC), but the network setup still applies to the computers.
Posted on May 31, 2013
Yellow light blinking
Typically, printers will blink a yellow light to indicate a communication problem between the printer and the computer.
1. Shut your printer and computer completely down.
2. Check connections to printer
3. Follow connected printer cables to the related computer port.
4. Check connections to computer
5. Turn the computer on and let it boot up
6. Turn your printer on.
Jan 20, 2013 | Office Equipment & Supplies
Tip
How to connect USB Printer to the Home Network or Sharing a Printer to multiple...
Connecting the USB Printer to network
1) Right click on My computer (
2) Click on Properties
3) Click on Computer Name
4) Click on Change (where it says "To rename this computer or Join a domain, Click Change")
5) Give Name to your Work Group
"Type the some Name in the BOX"
6) Click OK and Restart the Computer
** NOW THIS COMPUTER IS A PART OF WORK GROUP **
(settings on Main Computer where the Printer is installed)
7) Now we can share whatever you wana share
8) Open control Panel
9) Open Printer and Faxes right
10) Right click on the Printer Icon and click on Properties
11) Click on Sharing
12) Click on share this printer and *Name the Printer if you want share
13) Click on Apply now this Printer is in Network
Network the Second Computer
13) Go to each computer
1) Click on Start - control pannel -
2) Click on Printers and Faxes
3) Click on Add a Printer
4) It will show Welcomr to Add Printer Wizard
5) Click on Next
6) Select "A network printer, or a printer attached to another computer
7) Select browse for a Printer and HIT NEXT
8) It will show you the WORK GROUP and when you hit on it it will show you the Printer
9) Click on Next and OK
Its Done the Printer is Shared and you can take a print out.
Note : The Main Computer should On in order to take Print-out
Hope this will help you connecting your USB printer to the Home Network
on Jan 21, 2010 | Office Equipment & Supplies
Printer error says no connection to computer, even though computer is connected and cables. connected. I have tried all the typical choices.
try this: 1) unplug the printed cable off the pc 2) uninstall fully the printer driver 3) get the latest version of driver ( make sure it is compatible with your win version) 4) install the driver w/o connecting the printer 5) restart pc 6) connect printer 7) follow instructions of "found new hard ware" ----- GOOD LUCK----
Jul 02, 2011 | HP Officejet J5780 All-In-One InkJet...
When I plug the USB cable into printer, computer does not see the printer. I have tried two different cables and ports. HP Tech support told me that there is something wrong with the USB connection port on...
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 11, 2010 | HP Photosmart D5069 InkJet Printer
My printer is not working
1. uninstall all the drivers and softwares related to your printer from your computer.
2. disconnect your device from computer.
3. restart your computer once and use the driver cd which came along with your printer and reinstall all the softwares and drivers again to your computer.
4. connect your printer to your computer when prompted to do so while installing the driver.
5. Now your printer should work fine as usual.
6. If not, please try printing after connecting your printer to some other computer and test it
I hope this is useful to you
Please rate the solution given
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Remove and check right cartridge
remove the cartridges from the printer. Then clean the cartridges contacts.
1. Shutdown your computer.
2. Verify that the unit is switched on. Unplug the all-in-one from
power and disconnect the connection port.
3. Wait 30 seconds.
4. Plug in the power only.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect
the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
If the issue persists :
press and hold the "#" and 6 buttons on
the front panel keypad while plugging in the power cord.
Mar 14, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Cable structure
DB25 F DB25 M
(Computer) (Printer)
2 2
3 3
4 4
5 5
6 6
7 7
20 20
DB9 F DB25 M
1 8
2 3
3 2
4 20
5 7
6 6
7 4
8 5
Dec 08, 2009 | Toshiba TEC B-472 Thermal Label Printer
How to map usb ports USB1, 2, etc.
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
Oct 02, 2009 | Dell Dimension 2300 PC Desktop
My computer cant find my printer its a lexmark 2600
Have you tried the following steps?
1. Power off your computer.
2. Power off the printer and remove the power cord.
3. Check the cable connection between the printer and the computer to make sure it isn't loose.
4. Put the power cord back in the printer and power it up. Do all lights show up as normal? Green? Or are some flashing?
5. Power on your computer.
6. Under the printers folder, right click the installed printer and go to properties. Print a test page.
How is the printer connected? USB or parallel port?
Apr 19, 2009 | Office Equipment & Supplies
Computers & Internet Logo
64 people viewed this question
Ekse
Marvin
Marvin
