Condensation. There is standing water under the vegetable crisper.
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
SOURCE: My GE refrigerator collects water under the
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
- This is when it leaks into the fresh food section.
http://appliancejunk.com/forums/index.php?topic=22.0
- And this link is when it's cause in the freezer section.
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you.
I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
SOURCE: my Hotpoint refrigerator is leaking puddles of
It is most likely due to a clogged defrost drain. I put together some instructions on cleaning the drain, follow the link below and let me know if it was helpful.
Drain Leak
SOURCE: Crisper is freezing
This is a bad damper and it would need to be replaced. Try turning the freezer warmer until you can get this fixed and move up your stuff from the drawers.
