SOURCE: My defrost heater is not working. Westinghouse
You did not mention if your unit was 120VAC or 220VAC parts replacement mandate you know exactly which it is your searching for as far as replacement part sources.
120VAC US parts source
220VAC UK parts source
Most often a Defrost problem is one of the following:
1. Defrost timer (there are 4 terminal timers MECHANICAL and Multi terminal ELECTRONIC timers) Any generic Defrost timer will work as long as you know the input voltage and the number of require terminals match.
2. The 60 Deg Thermostat
3. The actual heating element
This company ships international USPS
Welcome to A-1 Appliance Parts
We are the ultimate source for the do-it-yourselfer appliance repair person.
USA Phone 1-800-841-0312
Here is a link to multiple Defrost timer examples. You should be able to match yours up with the images on this page. It may take a while but you can do it.
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=Defrost%20timer&ST=BIP
After a US Westinhouse search I get the feeling you may have to do a web search for "appliance repair parts UK" I hope this was of some help. (Last time I was in your area was 1997 US Navy....)
SOURCE: Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
