Question about Electrical Supplies
How to fit dimmer switch
Fitting new dimmer switch in living room
Posted by Jackie Wynn on
Joel Friedenberg
    Genius:
  • 1,114 Answers
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
Posted on Jun 05, 2014
2 Related Answers
Anonymous
  • 337 Answers
SOURCE: different outlet went out after installing dimmer.
It's possible that he living room outlet feeds through the dining room switch and that a wire may have become disconnected when you put in the dimmer. I don't know the specifics of you home layout. If the dining room and living room are on different circuit breaker switches, this is not the problem.
Posted on Feb 28, 2010
psycodelek
John Ziehm
  • 206 Answers
SOURCE: i have a dual dimmer
twist the kitchen and live wire together and use that for the hot side of your dimmer for the livingroom
Posted on May 06, 2011
VESPA PX 200E AFTER NEW REGULATOR FITTED , LIGHTS BLEW ?
Visually inspect ALL fuses inside the cabin and under the hood then inspect ALL lightbulbs..Turn signal bulbs..Etc..Do check your dimmer switch,if available..My dimmer switch was bad in my 2010 Hyundai Elantra GLS and my headlamps quit working properly..They(light)had led halos that wouldn't work..The line of LEDs under the unit(headlights) didn't work..All my dash lights went out and my taillights went out too..I checked everything known to man and found out it was that switch..I replaced the dimmer switch and EVERYTHING WORKS!! Hope this helps you..
Oct 18, 2018 | Cars & Trucks
How do I fit outdoor light
Electrician. That way you wont get shocked. You cannot see electricity
Aug 28, 2014 | Electrical Supplies
Different outlet went out after installing dimmer.
Feb 28, 2010 | Electrical Supplies
Hi, I've got a problem with inset spotlights
check your wirenut connections in the first fixture. over time, perhaps, the wirenuts may have come loose. other times there is a thermal overload in each fixture which opens because of excess heat.
Oct 25, 2009 | Electrical Supplies
I have bought Crabtree dimmer switch but it came without wiring instructions. There are 3 terminals, one marked L1, one L2 and the other with a wavy line with an arrow across it. Which one does the 'line'...
This is a 2way dimmer the wavy line is the common so your live supply will connect to this terminal .For 2way switching your strappers go in L1 L2 if you only require 1 way switching use either for your feed out to the fitting and disregard the spare terminal.
HTH
Oct 21, 2009 | Kitchen Appliances - Others
Downstairs toilet light switch needs rewiring
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Dec 07, 2008 | Electrical Supplies
Pull switch wiring !!
Connect the black wire to live. and the white wire to neutral. I hope this will help you.
Nov 23, 2008 | Solar 2-wire Pull Chain Light Switch For...
Electrical Supplies Logo
273 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
