Question about Zenith Z32X31D 32" TV
In auto program only the first 13 channels are found?
When I try to auto program my TV on cable only the first 13 channels are found even when channels above 13 are added. Help
Posted by gerry_yvonne on
Anonymous
  • 126 Answers
Sounds like bad tuner try to program manually and see if it will hold memory
Posted on Mar 21, 2009
Trying to tune tv but it will not tune in to channel 7s and channel 10s . Have tried auto and manual tune. suggestions?
Good day!!
Example Situation:
If you can get the first thirteen channels, then that proves there are no broken wires or damaged equipment between PVN and your room. Your cable - all 67 channels - has already been activated before you even move into your room. So, if you are only getting channels 2-13, you definitely have a programming problem with your television. We understand that your TV probably worked great last year or at home, but you have to set it up from square one when you move in to Penn again. Many times when you unplug a cable-ready TV, the memory settings are lost, and you have to start over. Therefore, you will need to program your set from the beginning.
If that situation happened to your TV please re-program your set.
Here is a link on how to re-program your Set.Just click the link bellow:
http://www.upenn.edu/video/setup/tsfaq.html#2-13
I hope your problem could be solve by this solution.Just add a comment for more query.Thank you!!
Aug 30, 2011 | Televison & Video
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
I can't get channels bwyond 13 and remote is gone so I can't reprogram for other channels. Can this be done withour the remote?
hopefully you have a menu button on your TV, if so you should be able to access auto program (you might have to search to find the auto search)but before you auto program make sure you set your TV to a cable setting then auto program. If you do not have a menu button on the TV, you could also try buying a universal remote. If you don't want to do that you could always use a VCR, just set your TV on channel 3 and do a auto program on the VCR ,using the VCR remote you should be able to tune in the channels your missing through the VCR.
Jul 07, 2009 | Televison & Video
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Oct 12, 2007 | Sansui COM312AD 13" TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Televison & Video Logo
197 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
