Amphion Mediaworks T-365 System Logo
Posted on Mar 20, 2009
Speakers not working with stereo
Hello Its seem as though I cannoth get the cent subwooker righ front and rear speaker to com on when i play the stereo . I have it hooke up properly , but here sound , Please help
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1751
Points
6
Take the disk out of the disk tray, go to setup and reset the unit under the preference menu to "Default".
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
403
Points
How can I get a remote for the T=365
I HAVE TWO YELLOW WIRED POWER AN WHAT..95 CAMARO REWIRING RADIO
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
2answers
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
2helpful
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
2answers
I'm looking for 1975 dodge charger radio wires colors diagram.Please help if You can,Thank You!
Hello mate, i can't find one for a 1975 model.
But try this one, checking that all colours are the same, if not do not use, Colin.
1984 Dodge Charger Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 5 1/4′
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
2helpful
2answers
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Ground Wire: Chassis or Strap
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
5helpful
3answers
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
I have a 1995 saturn sc1 and im having trouble finding the stereo color codes for it without buying them somewhere
Hello! Here you go!
Hope this helps!
-KC GTO Dad
17helpful
4answers
Chrysler town and country wiring diagram
Where is the amplifier located on a 2002 Town & Country? My stereo seems to be working, but there is no sound coming out of the speakers.
1helpful
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Top Amphion Mediaworks Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
