Question about Dishwashers
Hobart ml 130017
I need to adjust rinse temp it reaches 199
Posted by richardsag on
  • Dishwashers Master
  • 18,438 Answers
There is a temp booster on that unit. A rinse temp of 190 is not out of the range of specifications. If it is too hot, you should adjust the incoming water temp
Posted on Jun 01, 2013
2 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: Hobart LXI
Question--As of today if you look at the display does it read add detergent or add rinse aid?Im asking you this because theres a chemical pump circuit board that senses the chemicals on this d/w.And if the d/w displays those the d/w will keep dumping det/r.a. in.Let me know,if this is not the issue i will get you into the service program and step you thru.
Posted on Nov 15, 2008
Anonymous
  • 41 Answers
SOURCE: Tank temp
check to see if your element is scaled up or your element may be damaged
Posted on Dec 11, 2008
Hi i am getting a P1 error on a HOBART AM15 ELECTRIC DISHWASHER
Most likely sump temperature probe needs replacing.
Oct 17, 2018 | Hobart Dishwashers
Does my 2002 Cadillac Seville SLS have a cooling fan switch, and, if so, where is it located?
Cooling fan switch ?????? Has a engine coolant temp. sensor , That inputs info to the PCM/ECM - engine computer ! The PCM / ECM interpits the voltage signal from software programmed into it as to what temp . of the coolant is . When the engine coolant temp. reaches
The PCM commands the low-speed fans ON under the following conditions:
• The engine coolant temperature exceeds approximately 106°C (223°F).
• The transmission fluid temperature exceeds 150°C (302°F).
• The A/C pressure reaches 199 psi (1372 kPa).
The cooling fans will switch from low to OFF when the coolant temperature drops below 102°C (216°F).
The PCM commands the high-speed fans ON under the following conditions:
• The engine coolant temperature reaches 112°C (234°F).
• The transmission fluid temperature is more than 151°C (304°F).
• The A/C pressure reaches 260 psi (1792 kPa).
• Certain DTCs are set.
The cooling fans will switch from high to low, except when DTCs are set, when the coolant temperature drops below 106°C (223°F).
The PCM turns on the cooling fans by energizing three different relay's .
Watch this video
Relay Driven Dual Cooling Fan Diagnostics
May 29, 2017 | Cadillac Seville Cars & Trucks
Not getting up to temp
Have you checked the boiler for scale? Also, the thermostat might be faulty. The over heat stat is separate from the operating stat. Chech them both for temp range
Sep 14, 2017 | Hobart AM14-253 Free-standing Dishwasher
Rinse temp too low, first it comes up to 180 degrees and then drops to wash tank temperature, WHY?
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Feb 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Can you tell me what temperature the dishwashers reach during each part of cycle--Dishwasher model is WDF902SA Food authority have asked this of me
The wash temperature for a high temperature commercial dishwasher should be around 140F AND 160F. The final rinse temperature should be 180F to meet health code regulations. The final rinse temperature is reached during the end of the cycle for a few seconds. If the machine is a low temperature dishwasher the wash temperature and rinse temp will be around 140 F to 160 F. The sanitizing of your warewash will be done by the use of chlorine or iodine in the low temp application.
Regards
Jan 18, 2010 | Westinghouse Dishwashers
Adjust rinse temp up on mod am14 ml110976
you cant adjust rinse temp on the am-14 ,ck. booster make sure all elements are working ck. rinse press. should be @20p.s.i
Jan 06, 2010 | Dishwashers
Uaable to reach the correct tempature
Your rinse Thermister is shot. Replace the thermister between the fill valve and the solenoid. Also be watchful of the 120V, ensure this is secured as there is two power sources. Is ya good
Feb 20, 2009 | Hobart AM14C-155 Dishwasher
Tank temp
Nov 21, 2008 | Hobart AM15T Dishwasher
Stuck in rinse cycle
Mimmi, If the water isn't reaching temp this will happen. It sounds like a heating issue.
Guest,
The spray arm being blocked will not cause this. Again your machine isn't heating the water to temp.
Oct 27, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
