Nokia C1 Cell Phone Logo
Anonymous Posted on May 29, 2013
Site that i should open my mms
Cant i login at the mozilla firefox?
Anonymous
Level 2:
Guru:
  • Expert 54 Answers
  • Posted on May 29, 2013
Anonymous
Expert
Level 2:
Guru:
Answers
54
Questions
Helped
3349
Points
218
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
  1. Press Menu (press Navi key)
  2. Highlight Settings and Select (press Navi key)
  3. Highlight Configuration and Select (press Navi key)
  4. Highlight Personal configuartion settings and Select (press Navi key)
  5. Press Add new(press Navi key)
  6. Highlight Multiedia msg. and Select (press Navi key)
  7. Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
  8. Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
  9. Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
  10. Highlight Access point settings and Select (press Navi key)
  11. Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
  12. Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
  13. Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
  14. Highlight Bearer settings and Select (press Navi key)
  15. Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
  16. Skip past Network type this should be set to IPv4
  17. Skip past Authentication type, this should be set as Normal
  18. Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
  19. Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
  20. Press Back (right soft key) six times
  21. Highlight Messaging and Select (press Navi key)
  22. Highlight More and Select (press Navi key)
  23. Highlight Message settings and Select (press Navi key)
  24. Highlight Multimedia msgs. and Select (press Navi key)
  25. Highlight Configuration and Select (press Navi key)
  26. Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
  27. Highlight Account and Select (press Navi key)
  28. Highlight giffgaff - MMS and Select (press Navi key)
  29. Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.
The settings are now complete.
hope that helps
1helpful
I cant open my facebook in page, saying Unable to connect Firefox can't establish a connection to the server at www.facebook.com. The site...
try to uninstall you mozilla firefox browser....then install it with a fresh copy of mozilla firefox.You can download it from http://www.mozilla.com
I cant open my mail on my mozilla firefox... the mozilla firefox cant open
REINSTALL THE FIREFOX THAT YOU HAD GOT OR UPGRADE TO HIGHER...
May 14, 2011 • Yahoo Mail
1helpful
2answers
Whenevr i open any secure site, it is not opening properly ? waht could be the problem.i am a old person please help.
your browser is having bug. Try this: download mozilla firefox from below link
www.mozilla.com/products/download.html
and try to open the site. it should work..
and do not tell anybody your login info..
cheers!
&ldquo;https://login.facebook.com/login.php?login_attempt=1&rdquo;<br />i cant open up my account....<br />it asks me to enter the e-mail and password but after that it cant load the...
may be you are under security/firewall that block the site. try to contact your administrator. or simply try to use proxy or tunneling site like www.hidemyass.com
or try other web-browser like Mozilla firefox, ie, Google chrome, opera, make sure flash and other plug-ins are installed correctly.
try to set your internet security mid-low... try to turn off or configure your firewall/antivirus firewall software it may block the site.
Cant login at all
Clear your browser cache, remove temporary internet files. To do this open browser select tools, options and select temporary files option. Restart the browser and check to login. If you cant login then reinstall your browser or change browser (mozilla firefox or opera)
Mar 12, 2010 • Yahoo Mail
Cookies
Open Firefox--Tools Tab--scroll down to Options---open Advanced---press CHECK NOW button to see if Firefox is your default browser. Set to default browser if it's not.
Open Firefox--Tools Tab--scroll down to Options---open/click PRIVACY--"accept third party cookies" should be checked.
2answers
I cannot open this websites in my collage library.
Hi!
Dont use explorer, use firefox or any other webreader, that will solve that problem of yours.
Good luck
Nic
6helpful
5answers
I can't open my mozilla firefox 3.0.5
i cant open movie intv.ru by mozilla
1helpful
2answers
Firefox Problems with Vista
I have had the same problem with Firefox and also remembering my login information in Vista. The XP operating system is fine the problem is only with Microsoft's Vista operating system. It could have something to do with Vista's security setup, either that or Microsoft is just kicking the competition around? Actually it's probably a little bit of both those reasons.
The only way I have been able to correct the problem is to download the IE Tab add-on. It allows you to set up a tab to open with the IE engine embedded. If you have a site that is giving you login problems, when it is open select the tools button. In the dropdown box select the IE Tab Options. The problem web site should be highlighted in the pop-up display box. Select the add button to the right and it will transfer the web site to the list of sites that you want to open with the IE operating engine.
Now that web site will always open under the IE operating engine when you start up Firefox. After you login to that web site if you go back to the tools button and select options again, you can save all opened tabs as your home page. Now when you start up Firefox you will still have all the advantages of Firefox and those hard to login web sites will automatically load and sign you in the same as they did before.
Someday Microsoft will probably stop teasing Firefox and let them in on what they have to do to get around this obstacle, but then again maybe not.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
