My fridge is freezing all kinds of stuff in the refrigerator side
Could you look inside the door near bottom outside frame of fresh food side and get the model numbers for me to assist you better. Also if you have a way to check the temperature as you change settings on the thermostat for the fresh food section. We need to see how the thermostat responds to changes in settings. If no changes then we need to focus on the thermostat. Also there is duct that comes from freezer that can have a damper opened or close to different settings. Let me know the model and I will pull up the drawings for your model. Thanks Sea Breeze
OK, may be the control board. Your refrigerator has a circuit control board to operate the temperature and defrost cycles. If you don't mind please enter your model number at my website and ask if there is any more options. You can buy a circuit board and carefully put it in or you will need to pay someone to come out to your home to do the work. I really don't like the circuit boards because they are easy to become damaged with power surge and age. Here is my link below, enter your model number in the model search feature and you will get a page full of similar choices. Just pick one don't mater they are about the same. Check prices of boards and decide which route you want to go. Click on link below..On left of screen on your model choose model 10 control parts. There you will see the control board.
http://servicepartstec.blogspot.com/
Sorry if I was not able to make this easier for you, Sea Breeze
KSRL25F
Fan at the top seems to be running all of the time. Temp stayed constant at 27* with changes in tempsettings.
