Creating a bootable disk
I have the files of a windows 7 all in one as folders. I want to make a boot-able disk out of that with the help of install.wim and boot.wim. If it is possible please someone come up with a solution.
Posted by Susobhan Dutta on
nascentcreed1
    New Friend:
  • 104 Answers
I have here a link the will guide you on how to create a bootable disk. Tech Support Booting In With Rufus
Posted on Mar 16, 2015
max carson
  • 7,627 Answers
Posted on May 29, 2013
5 Related Answers
Anonymous
  • 221 Answers
SOURCE: boot error accures
THE BEST SOLUTION IS TO FORMAT IT AND REINSTALL THE OPERATING SYSTEM. IF YOU DON'T KNOW HOW TO DO SO, BETTER CONTACT YOUR SYSTEM VENDOR OR IT PROFESSIONAL.
Posted on May 20, 2008
Teet Bergmann
  • 565 Answers
SOURCE: Sony laptop VGN-N130G will not boot.
use any windows xp disk boot from it and use R key to repair windows then type fixboot
if helped rate fixya
Posted on Jan 05, 2009
Chris
  • 197 Answers
SOURCE: NO BOOTABLE DEVICE ,INSERT BOOT DISK
Generally this is an indication that your hard drive has gone bad, and is no longer visible to the computer. If your still under warranty, call Acer for service; if not, either order and replace the Hard Drive, or take it to a local shop, and they should be able to help you.
In this type of situation, chance are that the drive has died in such a manor that you won't be able to recover any data from it, but you could always ask the shop to try.
Posted on Jan 20, 2010
Azrael SRL
  • 11800 Answers
SOURCE: I have a HP 6730s.
If the dvd isn't working at all then this isn't a BIOS problem, it's hardware - the dvd unit has failed. You must replace it - a repair shop will ask you about $100 for the new unit and the labor.
Posted on May 21, 2011
ashlocked
Christopher Lozada
  • 1140 Answers
SOURCE: "No bootable device -- insert boot disk and press
Try this :
What is WinToFlash
There may come a day that optical drives are as hard to find as 5.25 floppy drives are today.
WinToFlash starts a wizard that will help pull over the contents of a windows installation CD or DVD and prep the USB drive to become a bootable replacement for the optical drive. It can also do this with your LiveCD.
You don't have to worry about scratches on the disc or misplacing your original media discs once you transfer their contents to the flash drive. The optical drive is quickly becoming a thing of the past, especially in office environments, as media is shifted to the cloud.
Take note: you have to select usb flash disk in your boot priority, how? just enter your bios then search for boot priorities.
DOWNLOAD
good luck....
Posted on Jun 06, 2011
Windows 7 instaiiation disc
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
Nov 11, 2012 | Computers & Internet
Tip
How to Install Windows 7 from a USB Key
Note: This guidewill only work within Windows Vista or 7. 1. Format Your USB Key
Plug in your USB key and back upany existing data stored on it. You'll need to format the key before you canmake it a bootable device. Open up a Command Prompt as anAdministrator. You can do this by finding the cmd.exe in yoruWindows/System32 folder, right-clicking the executable, and selecting "Run asAdministrator". Alternatively, type CMD in the Start Menu search field andactivate the Command Prompt using Ctrl + Shift + Enter. You should be underc:\Windows\system32 (assuming your Windows partition is the C drive). Type"diskpart" in the command line to enter the Disk Partition command line tool,which lets you format and create partitions on active disks. Type "list disk" to reveal a listof all your active disks, each of which is associated with a number. Make anote of which one is your USB key, based on the capacity. In our screenshotbelow, our USB drive is Disk 6 (8GB). Next, type the following commands,one at a time: Select Disk # (Where# is the number of your USB disk. We typed "Select Disk 6") Clean (removes anyexisting partitions from the USB disk, including any hidden sectors) Create Partition Primary(Creates a new primary partition with default parameters) Select Partition 1(Focus on the newly created partition) Active (Sets thein-focus partition to active, informing the disk firmware that this is a validsystem partition) Format FS=NTFS(Formats the partition with the NTFS file system. This may take several minutesto complete, depending on the of your USB key.) Assign (Gives theUSB drive a Windows volume and next available drive letter, which you shouldwrite down. In our case, drive "L" was assigned.) Exit (Quits theDiskPart tool)2. Turn the USB Key into a Bootable Device
Insert the Windows 7 install DVDinto your drive, and view the files that it contains. Copy all of the fileshere to a folder on your Desktop. We put the disc contents in a folder named"Windows 7" Go back to your command prompt,running it as an Administrator. Using the "CD" command, find your way to thefolder where you extracted the ISO files. Your command line path should looksomething like "C:\Users\USERNAMEHERE\Desktop\Windows 7\". Type the following commands: CD Boot (This getsyou into the "boot" directory) Bootsect.exe /nt60 L:(where 'L' is the drive letter assigned to your USB key from the previous step) Bootsect infuses boot managercompatible code into your USB key to make it a bootable device. IMPORTANT: Ifyou're currently running 32-bit Windows Vista or 7, Bootsect will only work ifyou use the files from the 32-bit Windows 7 install disc. The Bootsectexecutable from the 64-bit version will not run in 32-bit Vista. 3. Load the USB Key Up with the Install Files
Copyall of the extracted ISO files into the USB drive. You don't need to do thisfrom the command prompt. Just drag and drop the files from the "Windows 7"folder into the drive using Windows Explorer. Your USB key is now all ready togo! Plug it into your target system and make sure you enter the BIOS (typicallywith F2 or F12) to temporarily change the boot order to allow booting from theUSB key before your primary hard drive or optical drive. On the next restart,your system should automatically begin speedily loading setup files off of theUSB key and entering Windows 7 installation.
on Oct 28, 2010 | Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
Apr 26, 2011 | HP Compaq nc6320 Notebook
How to boot my laptop into usb drive
You have not specified your operating system. However I will explain how to do it with windows 7. First you have to create a bootable flash drive. Do it as follows
Format USB flash drive to NTFS format(For Win XP only. Vista users can directly format the USB drive to NTFS format) In your Windows, go to Control panel -> system -> hardware -> Device manager.
Under the disk drives section, right click on the USB storage drive and select Properties.
device-properties.pngGo to the Policies tab, select optimize for performance. Click OK.
device-policy.pngOpen your Windows Explorer, you should see the USB storage drive in the inventory. Right click and select Format. Select NTFS from the drop down bar. Click Start.
format-ntfs.pngFor Windows XP,
Download MBRWizard. Extract the zipped files to your desktop.
Open a command prompt (Start -> Program -> Accessories -> Command Prompt).
cd Desktop/MBRWiz2.0/
MBRWiz /list
Record the USB flash drive disk number
mbrwiz-list.pngMake the USB drive active.
mbrwiz /disk=X /active=1
For Windows Vista,
On the Start menu, navigate to the command prompt entry. Right-click and select Run as administrator.
vista-command-prompt.pngType
diskpart
list disk
Record the disk number of your USB flash drive.
vista-diskpart.pngSelect the USB disk.
select disk X (X is the drive number of the USB flash drive)
List the current partition. Record the partition number.
list partition
Select the current partition and make it active.
select partition Y (Y is the partition number of the USB flash drive)
active
list-partition-vista.png Creating bootable USB flash driveDownload Windows 7 iso (32-bit) file to your desktop (The download link is no longer valid).
Download and install WinRAR.
Right-click on the Windows 7 iso file and select Extract files. Extract the files to a folder (you can name the folder any name you want, but for illustration purpose, I name it win-7) in your desktop.
extract-win-7.pngIn your command prompt, cd to the windows 7 folder.
cd Desktop/win-7 (Change the destination to the folder that you have extracted)
cd boot
bootsect /nt60 X: (X is the drive latter of your USB drive )
bootsect-success.pngNow, copy all the files from the Windows 7 folder to the USB flash drive.
Reboot the computer. Remember to change the first boot device to your USB drive in the BIOS.
You should be able to install Windows 7 from your USB flash drive now.
Apr 26, 2011 | Sony Vaio Pcg-Z505N/Bp...
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Writing bottable disk
Here are the instructions, taken right out of Nero's manual for Burning ROM 8. page 42:
9.3 Creating and Burning a Bootable Disc
To create a bootable disc, proceed as follows:
1. Click on the New button in the main Nero Burning ROM screen.
�� The New Compilation window is opened.
2. If you want to create a bootable CD, select the entry CD from the combo box and the entry
CD-ROM (Boot) from the list box. If you want to create a bootable DVD, select the entry
DVD from the combo box and the entry DVD-ROM (Boot) from the list box.
�� The tabs for the bootable disc are displayed; the Boot tab is in front.
3. If the template data for the bootable disc should originate from a logical drive:
1. Select the Bootable logical drive option button in the Source of boot image data area.
2. Select the entry you want from the drop-down menu.
If the logical drive you want does not appear in the drop-down menu, the reason for this is
that the drive is bigger than the space available on the disc. Please note that for operating
systems as of Microsoft® Windows® 2000 you need to have administrator rights in order to
be able to access drives directly, which you will need to do if you are to create bootable
discs.
4. If the template data for the bootable disc should originate from an image file:
1. Select the Image file option button in the Source of boot image data area.
2. Click on the Browse button and select the desired image file.
3. Select the language that should appear while the system is booting from the Boot locale
drop-down menu.
4. Check the Enable expert features box and select the emulation type for the image file
from the Emulation type drop-down menu.
5. Select any other options required on the tabs (see New Compilation Window).
6. Click on the New button.
�� The selection screen is displayed.
7. Select the files/folders that should be written to the ISO part of the bootable disc and drag
them into the compilation area.
�� The files/folders are displayed in the compilation area and the capacity bar indicates how
much storage space is required on the disc.
�� You have now created the bootable disc and can start the burn process (see Starting
the Burn Process).
Feb 06, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
How to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Sep 28, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
46 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
