Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Question edited for clarity and translated to English.
A CH 24 error code indicates a pressure switch error. To Resolve: Make sure the air filter in the unit is clean. Remove any items or reposition the unit so that the air flow is not obstructed. Apr 25, 2023
parts and labor cost very all over earth, vastly and so does what is wrong. only knowing what is wrong matters. costs are estimated last, not first ever on any complex machine. talk to the last guy that damaged the loop.. good luck with that refer.
Split System Air Conditioner
Considering this, what does Ch mean on LG air conditioner? It is not a problem but it is just the reminder to clean the filter of the air conditioner. ... LG Split System Air Conditioner Error code = 05 LG AC Fault Definition = Communication(Indoor Outdoor) - Communication Issue. Indoor Status = Off.
Error Code 38 on my LG Split Air Conditioner.
I call LG Mexico and they told me a Gas Leak.
Called in the Gas Guy, filled with new Gas and fixed the leak, now the AC works again. Nice.
Thanks for the post by Posted by Bill L on Jul 14, 2012. I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
What is the problem ch 54
Why don't u give us an answer
