Question about Hayward Pool & Spa
Wiring diagram Need wiring diagram for Hayward Max-flo II model # SP2707X10 ingroundpool pump for 120 volts
1 Related Answer
john224
John Prohaska
  • 1378 Answers
SOURCE: I am installing a Hayward Pool pump max flo II at
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Posted on Sep 15, 2009
Testimonial: "That's outstanding info for anyone installing a pool pump. Tom Smith"
Lubricate bearing
i dont know of anyone who sells bearing for motors find someone who sells hayward give them the model and serial number off the pump you need a new motor dont forget you also need new seals
Mar 01, 2014 | Hayward Pool & Spa
Electrical cord hookup switch 230 to 115 hayward
When you take the plate off of the side of the motor, there's a diagram there that shows you how to hook it up to 220 or 110
Aug 02, 2012 | Hayward Max Flo II Pumps MaxFlo II Single...
I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
Jul 18, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Three pvc pipes coming into an max i flo pool pump should all three valves be open to run the pump?
Here is a link for the users manual for these pool pumps. You should be able to not only see a diagram, but also read all about which valves should be open and which closed.
http://www.backyardcitypools.com/images/hayward/power-flo-manual.pdf
Jun 19, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Sep 15, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
62 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
