Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
http://waterheatertimer.org/Replace-anode-rod.htmlIf anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
