Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Removing television base
I am trying to remove the base from my 37" insigna lcd television so that i can wall mount it but i cant seem to remove the base. help
Posted by pb4now on
Joe Hogan
  • 10,865 Answers
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Posted on Mar 20, 2009
Cant take the stand off to mount on wall
either a couple of screws underneath or on the bacck side usually some arrows indicating the screws to be removed ok
Dec 17, 2010 | LG 37LC7D 37 in. LCD HDTV
I am trying to mount my LG 37" on the wall and cannot figure out how to remove the stand that came with the tv
37LG30 - loosened the 4 screws on the back of the TV but base mount wouldn't come off. Found that had to remove the screws even though already loose so that doesn't bind in the holes. Did this by making the loose screws bind in the wholes. Using twisers in the whole would have done the same thing. o
Dec 27, 2009 | LG 37LG30 37 in. LCD HDTV
Remove base off my 37 inch hatachi tv we hung on the wall
there are 4-6 screws or bolts on back near middle bottom of tv usely marked with arrow or S
Nov 28, 2009 | Hitachi 37 in. LCD TV
I want to mount the Mintek D373 on the wall.
There are four screws on each side of the back of the TV(toward the bottom) - You have to remove those.
Apr 05, 2009 | Mintek DTV-373-D 37 in. LCD HDTV
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
Dynex TV
You have to take the back off.
Sep 06, 2008 | CTL Nexus NX3200 Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
LCD
Most Protron and Ultra branded bases can be easily removed by just unscrewing them. Just a few simple screws and it should come right off. May need to flip it over and just take a look at where it's screwed into the TV itself. Hope this helps!
Dec 31, 2007 | Protron PLTV-37 37 in. LCD Television
Remove the base
There are 4 philips head screws down near the base, 2 on each side. Remove those and the base will slide out.
Good Luck!
Dec 24, 2007 | Sylvania LC370SL8 37 in. LCD Television
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
176 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
