Sir,
first port of call is to right click on a blank bit of the desktop and choose properties from the menu,you should find a section with your monitor refresh rate on it,this is usaully set to 60hz by default,75hz or above should get rid of flicker if your monitor supports higher.....failing that,have you got anything recently placed near it that could interfere with signal such as a mobile phone?.....also check cables for condition and plug is secure.......if these fail you might have a fault developing in your graphics card or if its a TFT screen an ilumination tube maybe faulty inside the screen
Thanks
Good Luck
Appreciate to rate as "Fixya"
Replace the inverter circuit board for the hi voltage supply to the back light for the LCD display.
Its the light inverter fault needs replacing.
That means that the inverter is gone.
If the screen is there, and the back light is not working, the inverter board is faulty and should be replaced.
The inverter is an high voltage board that supplies AC power to the backlight.
The part number is PWB1865, you can order here: Index Buy Refurbished KDS KDS INVERTER.
Verify part number with your model number with the seller before ordering.
When back light inverter got defective, monitor behaves like that.
You need to replace back light inverter board for continues operation.
You should contact KDS Support for parts.
Welcomejee: I don't think I have an extra inverter board, where can I buy one? how much will it cost me?
It seems Welcomejee is taking a break, can anyone help?
You seem to be having too many customers, loosing one will do you no harm.
