Question about Avaya Partner 18D Display Phone (315807BA)
Avaya 18D unable to make outgoing calls
I have an Avaya 18D that I was programming speed dial number into. When I finished I noticed I was unable to make phone calls. When I place a call the receiver does not give me dial tone or ringing, just a beeping noise. Thanks
Posted by bbcalagu on
george peters
    President:
  • Avaya Master
  • 860 Answers
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Posted on Mar 20, 2009
Avaya Partner 18D Corded Phone...
Yes. Call forwarding is a feature provided by your telephone company, not a feature of any phone, and the procedure is dependent on the company. For some telephone companies, for example, you forward a call by dialing *72, waiting for a second dial tone, then dial the number to which you want calls forwarded. Please contact your telephone company for their exact procedure.
May 28, 2012 | Avaya Corded Phone avaparp18d
How to active the follow me feature on a avaya partner phone 18d ?
Activation is easy, programming not so much. It's F11. There are about 10 conditions that have to be met, like the number has to be in peronal speed dial and call coverage needs to be on for outside lines to forward.
The form is F11.xx.xx
Carl
May 12, 2012 | Avaya Corded Phone avaparp18d
Have a lucent partner 18D system How do I change
If your changing the speed dial numbers under the individual buttons thats done by pressing feature 00, the button you want to change the speed dial number on, and enter in the new number.
If your changing the system wide speed dial numbers, From extension 10 enter in feature 00, press feature then the 3 digit code for the speed dial bank (600-699), then enter in the new telephone number. Either press feature and the next 3 digit code for the next number or press feature 00 if finished.
Jan 25, 2010 | Lands Phones
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
Programing Ayava partner - 18d Phone
This will need to be done at Extension 10 or 11.
Press Feature 00
Press LEFT intercom, LEFT intercom
Press right intercom. Display will ask for an extension number.
Enter the extension number you want to modify.
Now it should say "program ExtXX"
Press * * (STAR STAR)
then touch the lines in the order you want to pick them up, when finished entering the order....
PRESS * * (STAR STAR)
Then Press Feature 00 to exit programming.
Apr 30, 2009 | Avaya Corded Phone avaparp18d
Erase an old speed dial #
Once you are in a programming mode and need to Remove press second row 4th buton from right to left.
This is an overlay
Second Row from right to left: Next Procedure, Next Item, Next Data, Remove
Third Row from right to left: Prev Procedure, Prev Item, Prev Data, Enter.
Apr 10, 2009 | Avaya Corded Phone avaparp18d
From extension 10 or 11
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
then the order you want the lines to get picked up (if you want to grab line 4 then 3 then 2 then 1, upon going offhook, press "** line 4 line 3 line 2 line 1)
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
Nov 25, 2008 | Avaya Corded Phone avaparp18d
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
536 people viewed this question
Top Avaya Lands Phones Experts
Marvin
Marvin
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
