Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
Kitchenaid beater rubs bottom of the bowl
My Kitchenaid beater is rubbing the bottom of the bowl. The white coating on the beater is completely worn away and there is a groove in the stainless bowl. How can I correct this?
Posted by melliemelo on
  • David Shaub May 11, 2010
    In the pivot at the back of the machine, there is an adjustment screw. It's probably under a cosmetic cover plate.
QuietRiot
  • 145 Answers
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
  • QuietRiot Jul 08, 2009
  • Lynda Hansen
    Lynda Hansen Dec 17, 2013
    Thank you so much...I can't tell you how many years I've been working with a broken beater! :)
Why ceramic is wearing off beater of kitchenaid mixer?
You need to adjust the head height. Raise the head and look into the hinge from the front of the machine. There is a single slotted screw there, anti clockwise to raise the beater from rubbing the bowl. Just enough to clear is all you need.
Jul 20, 2014 | KitchenAid K45SS Classic Stand Mixer
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid KP2671 Professional 6 Series...
Beater rubbing bowl
Although I can't find your mixer by the model number you gave me, I assume that your mixer is the kind which the bowl moves up and down not the "tilt-head" style.
See pg. 12 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707946.pdf
There is a screw in the base of the mixer which is turned
clockwise to raise the bowl
and counterclockwise to lower
the bowl.
Apr 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
The flat coated beater has worn off the coating why and how to fix it
Hi ARADAM, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Food Mixers
Mixer component vibrates; seems to sit too low; beaters rub against bowl; alignment seems wrong
Hi, LAHR, by the symptoms you describe it appears that it’s time to adjust your mixer’s "Beater to Bowl Clearance" adjustment screw, which should be a pretty easy to do by yourself.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of it from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
I hope this helps! – Howard, Burke, VA
Dec 09, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
Help with replacement parts
Your beater to bowl adjustment may have come out of alignment, which can happen over time with normal use of the machine. This simply means that the flat beater may be contacting the bottom of the bowl.
In your mixer's Use and Care Guide, the beater to bowl adjustment is covered and will provide easy instructions to follow about how to adjust your beater back into proper position.
There are burnished aluminum beaters available. That is to say, they do not have the food-safe nylon coating on the outside of them. Burnished aluminum beaters may not be used in the dishwasher, require hand-washing, no soaking, and immediate towel drying. Failure to follow exact washing instruction with burnished aluminum beaters may result in tarnishing of the beaters.
May 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Paddle is rubbing the bottom of the mixing bowl
It is going to low down. the adjustment should at the back of the unit.
Mar 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater rubbing bottom of bowl
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid Artisan Series Tilt-Head Stand Mixer Logo
1,078 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
