Question about JVC AM FM CD DET FACE CAR STEREO
Jvc KD-G441 not working
My jvc kd-g441 does nothing when i turn the ignition on in my car after adding the stalk controlle adaptor in my peugeot 306
  • 1 more comment
  • Anonymous Mar 21, 2009
    it was the fuse :) many thanks though haha much stress caused by a little fuse :( now if only i could get the stalk adaptor working with the jvc unit
    yeah well i followed the instructions and now have a fully working stalk controlle :) many thanks for the help
  • Bluebird007 Apr 09, 2009
    My JVC KD-G441 will accept and eject disks but won't power on. Could this also be fuse related?
Anonymous
  • 58 Answers
U EITHER HAVE A POWER SHORTEGE, OR U HAVE A BLOWN FUSE
Posted on Mar 20, 2009
Testimonial: "sorry its been awhile , it was a fuse that had blown i connected something wrong and it must have tripped it many thanks for your help !!"
    SOME CARS WILL REACT TO THINGS DIFFERENT.
    NO PROBLEM, U CAN ASK ANY THING ANY TIME
I put a cd player into my car, when i turn the ignition on it lights up but then goes out seconds later and then if i try again it doesnt light up at all. iv had the cd player in other cars but its worked...
Put a multi meter or test light on the red wire and separately the yellow wire. You should get constant 12v on the yellow wire and ignition switched 12 volts when the key is turned on the red wire. If one isn't working properly check the respective fuses. Also make sure your radio is grounded properly. Sounds ground pins in car radio harness run to know here on the back end of the harness.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 04, 2017 | Car Audio & Video
Hi I have a JVC KD-G801 car cd player/radio. Today a mechanic uninstalled it from a car I have which I will be selling and he installed into a newer Peugeot 306 I bought at the weekend. The stereo is...
Yes... the wire designated for constant power which powers the clock and some of the lessor memory functions is disconnected.
I would remove the radio and look for the lead that is disconnected and have a constant power lead attached to it to cure this issue.
Have the mechanic who did it the first time do it.. as it was already paid for him to do so in the first place...
Oct 06, 2010 | JVC KD-G801 CD Player
Can I connect a CD interchanger
Hi
Yes it can be! but in this case you need a qualified technician to convert the wiring. or if the connector is the same try it.
Thanks!
Jun 07, 2009 | JVC CH-X350 12-Disc CD Changer
CD magazine trapped in Ford CD changer, no power to release
there is a way to get it working with the ford radio as long as the ford radio is cd changer compatible. You can purchase an adaptor from a dealer of autoleads. They also have a website. http://www.autoleads.co.uk/ were you can find out if its compatible and what lead you need. As far as i can remember with the jvc changers there is a seperate lead for power for a changer which you have to earth to the body of the car aswell have you got this
May 19, 2009 | Car Audio & Video
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
Changing car radios
Hi I disconnected the battery and but that on charge i removed the radio and checked all the wireing and i think what i may have found when the guy who installed it in the first place, when he was putting the radio in place with the wiring the jack plug to the remote stalk control had come detached.
thank you
denis
Jan 26, 2009 | JVC KD-G430 CD Player
Jvc kd-g441 usb car stereo unit
Here's what Halford's told me to do; Remove the unit (by taking off the front bit, then using the keys to get the main bit out). You should see a red and a yellow power cable. Take the red and yellow cables out of the sockets, and swap them. This apparently re-orients the power and allows the unit to store data and resume playback etc more effectively. Hope it helps...
Jul 20, 2008 | Car Audio & Video
I have a JVC KD-G441, which I have just put in the car. However, the preferred settings do not get saved if I turn off the engine. Does anyone know why? The car is a Peugeot 206 SW, if that helps. Jade
For all car cd players their is connector back side of the cd. having bunch of wires, in that if you connect squencily , the colour code of the wires are as follows
1. black for earth
2. red for acc, that you have to connect through ignition key +12volts
3. yellow, +B for continous supply that is battery
4. white and white with black stripp for front speskers
5. greay , greay black for front speaker
6. voilet ,voilet black for rear speaker
7. green, green black for rear speaker.
8 blue, for system remote .
if your yellow wire of +b is wrogly connected then memory problems comes
please try
regards
sam
Jul 12, 2008 | JVC Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
361 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
