The problem that you are experiencing with your Canon GL2 camcorder is a common complaint on this model camcorder. The eject the tape error is the camcorders way of saying something is wrong and it needs to be sent in for repair. It is not a defect with the camcorder, it is simply the most common complaint when the mechanical assembly is not running smoothly and perfectly. There are parts of the mechanical assembly that over a period of time wear and also possible defective parts that can cause this problem. The average repair cost for this repair is usually between $250 and $450 parts and labor. This also includes cleaning and servicing.
Sincerely,
Sheryl Bahr
www.VideoOneRepair.Com
888-283-2228
The immediate remedy may be cleaning the video heads. The head is not receiving the data from the inserted tape because it may be clogged. Use head cleaning tape for about 10 seconds but NO MORE. Try again, if not you may need to clean and adjust by trained technicians. Good luck -James. For further assistance, go to www.camerarepairjapan.com
