Canon LC-3175 Laser Fax Logo
Question about Canon LC-3175 Laser Fax
The machine squeaks when printing
Not only when printing, when it is turned on. have used wd-40 and compressed air to try to clear it out
Posted by vivien troy on
I used WD-40 just once. How can I know if I damaged it completely?
WD-40 probably hasn't killed it, most of it will evaporate in time. It can cause the shredder to get gummed up with little paper particles so you might need to clean it out with some compressed air. I wouldn't use any sprays on a shredder unless Fellowes recommends it.
Bobbin shaft will not turn, I have it pushed all the way to the right
Sometimes the bobbin winder gets frozen and will not turn any longer. Try a little WD 40 to get it loosened up, blow that out with compressed air then oil up with sewing machine oil.
Squeaking
I am in the same boat, currently looking for an answer on this one. It is a really abnoxious squeak. Tried WD-40 but no luck. Not sure where the problem is even coming from.
1helpful
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 • Dryers
Machine making squealing sound in wash and spin cycles like a bearing is loose or something. how do you fix this?
Use WD-40. No tools needed. Tip the washer on its backside and remove the beltaa79289.jpgTurn the main drive pulley to release the brake and spray some WD-40 under the brake liner. The squeak will magically disapear.
Rate it or hate it:dc9b641.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Cant turn angle adjuster on table saw model 3400 craftsman
I would first look for debris/sawdust on the mechanism, clean it with compressed air and then try and find a dry spray lubricant if not temporarily use some WD-40 to free it up
3helpful
Dragging motor and squeak
Absolutely! WD-40 is NOT a lubricant. I've been using Hoppes gun oil, but 3-in-1 oil will work, and you might find oil labeled for use on electric motors at an appliance parts seller.
Squeaking rear wheel on Maclaren Mac 3
Hi jimmacd, W-D 40 is the perfect solution. It will not attract any dirt or cause problems in the bearing assembly.
old marine
old marine
Marvin
Marvin
