Question about American Standard Plumbing
Speed connect drain will not go down completely
Followed directions on how to adjust the cam and when i pull the 'lift rod' up, the stopper will still not go down and be flush with sink. Used different settings on cam. Turned it all the counterclockwise and it will not move at all. Clockwise, it will go down some but not all the way. Now here is the strange thing; when I pull the whole unit out of the sink and attach the 'speed connect', the stopper goes down all the way. What am I missing?
Posted by ntrlvr1630 on
  • 3 more comments
  • ntrlvr1630 Mar 21, 2009
    There is no compression nut on this faucet. There is a cable that attaches to a 'cam' on the drain tube. This is how the 'speed connect' functions. Aparently all American Standard faucets use this 'speed connect'
    There is plenty of play in the cable and it is sealed so no way to put oil into it. I will try turning the tube to the side although the directions say to face the rear. if that does not solve it; will call American Standard and let you know. Thx
    The only thing one can do with the plunger is to leave it in the locked or unlocked posistion. Directions say it is to prevent tampering. Whatever...nothings easy
  • ntrlvr1630 Mar 25, 2009
    To dlmcmasters...I fixed the problem. It was such a blonde manuever; and I can say that cause i'm blonde. I had the sink on the edge, while working the plunger, instead of right side up so...gravity was my enemy. It works fine now
  • Anonymous Dec 10, 2018
    Thanks, ntrlvr1630. For others stumbling across this thread, here's my comments. I had a Covina faucet with the Speed Connect on an older vanity. Moved the faucet to a new vanity, and found that the pulling the lift lever up didn't drop the stopper, but it did push the stopper back up when I pushed the lever down. The cable was turning in both directions; I took the cam out and made sure that there was only one way to reinsert it. Followed the AS directions on fine-tuning it and nothing helped. I analyzed the interplay of the stopper loop and the cam and while I could see how it push up on the bottom I didn't see any way they interacted to pull it down. I was on hold with AS tech support and scouring the net for answers and came across this thread a few minutes before the guy finally answered. He confirmed ntrlvr1630's statement that the drop of the stopper was purely gravity induced, and wasn't "pulled" down. I not only had the same issue that while I was working on it with the sink tilted, but I still had some gunk in the drain that was impeding the free sliding of the plunger.
Donni Steen
  • 687 Answers
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
Posted on Mar 20, 2009
  • Donni Steen Mar 21, 2009
    You must have the "Cadet" faucet. I installed one of these before. Is the "cable" torqued somehow? I know that the cable is one size fits all. Sometimes it can be a tight fit and the cable has too sharp of a bend in it. If you can't get it your self, call American Std. they will be able to trouble shoot the problem more acuratly. These types of problems can be frustrating. Also, if the cable is coming into the drain assymbly from the rear, try turning it to the side. Try different angles and see if that doesn't free up the cable on it. I have forgotten, is there anywhere on the cable that you can put a couple of drops of 3 in 1 oil into it? Let me know what you find out and if you have any more questions. I'm here to help!
    Your welcome, I thought that there wasn't a way to lube but it has been over a year ago I installed that particular faucet. I didn't have any trouble at the time. Also one more thing........the trim piece on the plungger its self, can you adjust it on this faucet? Most faucets can be adjusted on stopper, plungger what ever you want to call it. You just turn it clockwise to make it more flush with the drain.
My son put tp down the drain. How do I remove the sink stopper? Doesn't seem to unscrew?
it unscrews but from the underneath up
you will have to remove the "S" trap only as what ever it is will be stuck in that bend
Jan 04, 2016 | Plumbing
The lift rod for my tuscany brooksville faucet is too short
If you are talking about the lift rod that opens and closes the sink drain stopper, then this is adjustable by moving a clamp on the rod. If the drain does open far enough then move the clamp.
Mar 26, 2014 | Plumbing
Sink pop up waste won't close
When you pull out the stopper is it completely intact? there should be a hole at the bottom of the stopper were a rod goes through. That moves on an axis pulling and pushing the stopper up and down as you pull and push the lever. You have to make sure you get the rod in that hole for the pop-up to work. You can google pop up assembly and look for an diagram. good luck
Jun 30, 2010 | KitchenAid Home
The bathroom drain stopper will not stay closed.
there is a small compression nut on the drain, it needs to be tightened slightly. look under the sink when you pull the lever up close the stopper, you will see where it connects to the drain. tighten that nut slightly.
do not over tighten or you won't be able to move the stopper at all, you just need enough pressure to hold the weight of the lifting rod and stopper in place.
May 12, 2010 | Home
Pop up raises only partialy, pop up not square in drain
YOU CAN TRY BY ADJUSTING THE ROD ,UNDERNEITH THE SINK ,MUST POP-UP ASSEMBLIES,HAVE A ROD COMING OUT OF THE DRAIN AND A ROD WITH SEVERAL HOLES ON ,IT TO ADJUST HOW FAR YOU CAN PULL THE ROD UP ,WHICH IN TURNS SHOULD MAKE THE STOPPER GO DOWN,ALSO A COMMON PROBLEM IS THERE IS TO MUCH HAIR AND TOOTHPASTE STUCK ON THE STOPPER ITSELF,SO SIMPLY UN SCREW THE NUT, THAT IS HOLDING THE ROD INTO THE DRAIN ,THEY LIFT UP THE STOPPER,THE STOPPER SHOULD NOT BE ABLE TO BE REMOVED WITHOUT TAKING THE NUT AND ROD OUT ,IF SO YOU MIGHT HAVE TO REPLACE THE WHOLE POP-UP ASSEMBLY
Mar 17, 2010 | Plumbing
Stopper came out Pegasus bathroom sink
Pegasus make several models but I'll make an assumption that it has a pop-up plug actuated by a rod just behind the tap head.
If correct....
Under the sink in the cabinet you will see the rod comes down and connects to an adjustment fitting and into the main drain line from the sink. There will be a fitting on the drain line holding the connection. Inside is a metal ball and connecting rod that links to your plug.
Remove the fitting.
Slide the ball and rod partially out.
Put your plug back in.
Engage the rod again (you will need to fiddle a bit here).
Tighten the fitting.
Run water to ensure the fitting is tight and not leaking.
Should be good to go.
Please rate this answer if it gives you some direction.
Dec 22, 2009 | Pegasus Technologies Home
Jacuzzi rotary drain
I don't understand the bend down rhing. The drain stopper, as you call it, has a rod that goes through the end of it to enable opening and closing with the vertical control.If I'm on the same page, under the sink on the backsie there is nut that holds the stopper control.. It has a nut you need to remove and line up the short end with the stopper slot, then put the nut back on to secure the ball. Don't overtighten. Now the log end of that same rod is secured with a spring clip to the un and down control rod . It can be adjusted by moving the spring clip up or down on the control rod. noyhing isbroken, just pulled apart or out of adjustment.
Nov 06, 2009 | Jacuzzi Rotary PVC Drain Kit DA34-815
Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Mar 15, 2009 | Home
Sink stopper will not disengage
Hi Im here to help. There is a lift rod that is connected to a pivoit rod that lifts the pop-up drain up and down. If this has become disconnected, or broken. heres a link (scrool down) to a picture of how it works.
http://www.hometips.com/content/popups_intro.html
Please remember to leave me some good feedback! Thankyou.
Dec 11, 2008 | American Standard Model 2373.801: Enfield...
Plumbing Logo
3,281 people viewed this question
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
