SOURCE: Candy GO1482 washing machine blows house fuse
This sounds like an electrical fault within your Candy washing machine.
Have you tried plugging your coffee machine, dishwasher or toaster into the SAME POWER SOCKET?
If so, does this still trip out the mains/house fuse?
If it does, it sounds like there is a fault in your house wiring.
If these "high power" devices/appliances do not cause the same problem, then you may have an Earth Leakage fault on your washing machine or something else inside it has short-circuited and will need servicing right away!
SOURCE: no power on washing machine
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
