Question about American Standard Prairie Field Single Toilet Paper Holder, Satin Nickel
Flapper will not go down
Toilet - American Standard 6.0 Lpf 1.6 gpf
After a flush - the flapper will not go down - I can take off the tank top and just touch the flapper - and it will go down. Have recently bought the house (approx 5 years old) - toilet has not been used for the past 7 to 8 months. Troy Howard
Posted by troymhoward on
Donni Steen
  • 687 Answers
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Posted on Mar 21, 2009
How do fix my American standard cadet 3 toilet?
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
2helpful
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
2helpful
Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
3helpful
Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
2helpful
Toto toilet keeps running. water is going into the pipe continuously.I am stupid about fixing this.....or anything.....any SIMPLE help? thanks
Turn of the feed line for the water. Flush the toilet. Then reach in tank and pick up the flapper valve. Clean around the seat of the flapper valve real well. Check for damage on the flapper valve and clean it as well. Put the flapper valve back in its seat and turn the water on to fill the tank. Then bend the rod for the float down a touch. This will put more pressure on the water valve at the top of the pipe in the tank. If this doesn't work, you may need to change your float valve. They wear out. The ones you buy in the DIY stores generally have diagrams and good instructions for installation.
1helpful
1helpful
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
1helpful
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
American Standard Prairie Field Single Toilet Paper Holder, Satin Nickel Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
