Question about Sharp Viewcam VL-A10U Camcorder
Is there a fuse inside the cam?
Power at the battery but the cam wont power up. Is there a fuse inside the cam? I put to much voltage to the battery adaptor.
My viewcam VL-E39 when on the button to the tape(power)LCD display on(lits) and off in a second its, went dark.The power is there and the sytem is dont work.I did not use for long years(4years)this may course a problem?
Posted on Oct 21, 2009
My DPF-1411 has stopped working, wont power on at all. I have tried plugging it into various plugs and holding down the power button but nothing happens. What else can I d?
do this steps:
1. check the power supply adaptor cord ,stranded wires inside sometimes breaks without your knowing.
2. Use a voltmeter to check the voltage output from the adaptor if doesnt react and no reading at all replace it .
3. if the powersupply is good, open the back cover and find the fuseable resistor inside the power source section of the board. replace it with the same value and put it back the cover and you are good to go. thanks
Dec 04, 2016 | Computers & Internet
My toshiba satilite L305D-S5940 Wont charge has new battery new power cord It comes on acts like its going to work then shuts off and sometimes wont come on What could it be please
1st : you can check from the power cable charge
2nd : check the adaptor charger if there is a light indicator or not, or you can check with multimeter to check the voltage on charger adaptor, does show the proper voltage for your laptop, you can check at the end of the connection that leads to the laptop.
note : Remember use DC current at Multimeter
3rd : if the adaptor running well, just plug on the adaptor charger to the laptop, dont turn on the laptop power, just see the light indicator with battery / lightning image on laptop, its explained that there is or is not the power current running to the laptop.
3rd.A : if its no power goes to the laptop then your adaptor charger is failed
3rd.B : if is there, there must be a problem with your motherboard, section power / power plugs, why do not want to charge with a new battery.
Conclusion :
- if the problem on number 1 & 2, then you can change the power cord and the adaptor charger.
- if there is problem on the 3rd.B then you can go to the toshiba services center for your problem.
thats all, hope its help.
Dec 01, 2015 | Toshiba Computers & Internet
No power in my laptop. I press power button and only see red battery light for few seconds.
please measure the output voltage from the adapter , see the label printed in your adaptor if the voltage read with the exactly voltage: exampe label printed: 17.8, and you measure 17.8 the adaptor is o.k
If do not the adaptor is faulty. repair or replace
However you must try with the battery to Start, of course the battery must be charged in full, if the battery is o.k the laptop will be on. If not the power supply inside is faulty. REPAIR.
God bless you
Jul 30, 2013 | Advent Modena M101
Power problem
*check u r electricity line 110-220V
*chek u r DC Adaptor power code
*check u r Adaptor out put voltage 12V
*check u r DC shocket pin
*check u r mother board power section
*take multimeeter then select dc range then chek dc out put voltage
*then chek main fuse and diode
Jun 20, 2011 | Computers & Internet
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
No power from ac adaptor
No, there are no reset button or fuse in these laptop adapters, they are a sealed unit. The lead/plug maybe broken at the plug. Test the voltage at the plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 21, 2009 | Toshiba Satellite Pro L300 Notebook
End of power cord has 20vdc. Whe it is plugged in the AC led does not light on the laptop. A65-S1066. How dead is it?
try checking the out put voltage from adaptor, if the adaptor has screws open it and check the fuse, remove batteries and check
Jul 08, 2009 | Toshiba Satellite A65-S1066 Notebook
Vmx
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Jul 02, 2008 | Nintendo DS Lite Console
Sony Viao, won't power up
Sir,
you remove your Laptop main battery and adaptor for aprox 10 min then fix again battery and adaptor then on power button m/c is on.
Mar 06, 2008 | Sony MBX-49 ASSY Motherboard
Sharp Viewcam VL-A10U Camcorder Logo
202 people viewed this question
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
