So,we have a router from pldt,zyxel p660 hn t1a, and we would like to know how it can be connected to our modem so that we'll have wifi.can it work?help please
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
SOURCE: my zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
SOURCE: want instructions on how to secure a zyxel prestige 900 router
I thought the 900 series zyxel was a multi ip address router modem, if your connecting a router or switch try supplying your gateway, dns info from your isp to the device.
SOURCE: i need router configuration password for Zyxel P-660H-D1 modem
Download a userguide from http://us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050726121025
I think the password is 1234 for admin mode
