Question about Frigidaire FMT148GP Microwave Oven
My Frigidaire over the stove microwave not heating food
My microwave makes a loud humming noise and a funny smell but does not heat the food. Is it something I can fix? Thanks for any help.
Posted by danodelia on
  • 1 more comment
  • Anonymous Mar 17, 2014
    when turn it on it makes a very lound noise does not heat and smells like something is burning
    making a lound humming nise smells like something burning and does not heat.
    makes loud noise smells like it is burning and does not heat
Anonymous
  • 38 Answers
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
MMV5100AAW Microwave hums and smells burnt , will not heat food , everything else works fine
If you have that funny burning smell in the microwave oven This is sure sign the magnetron has failed, and must be replaced.
Mar 21, 2012 | Maytag MMV5165 Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
My Frigidaire microwave is less than a year old. It is making a loud noise while running. So it runs loudly but does not heat up food. Is there a simple fix or did I get a dud?
The symptoms of loud noise and no heat indicate a short in the magnetron or high voltage diode. Need to take it to a qualified repair, to figure out what the problem. The magnetron replacement can cost as much as a new oven. See what the warranty covers, maybe you might luck out.
Dec 07, 2010 | Frigidaire FGMV174K Microwave Oven
Heat element not working
Well, if there is not heating the food and making a loud buzzing or humming sound when it is on, then the magnetron has failed. It typically shorts out and fails. The magnetron for this cost $140 plus the cost of the service call, you're better off buying a new oven. Hope this helps.
Jul 07, 2010 | Frigidaire FMV156EM Microwave Oven
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Frigidaire FMT148GP Microwave Oven Logo
930 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
