Question about RCA F27242GY 27" TV
TV TURNS ON AND OFF
MY RCA T V MIDDLE OF NITE TURNS ON &AND OFF HAD TO UNPLUG
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
My experience with the RCA F27242GY 27" TV going on and off is as follows:
Where the coaxial cable connects at rear and the base of the TV chassis part # 15062-57A is loose.
Posted on Sep 20, 2009
6ya staff
SOURCE:
RCA LED48G45RQ TV turns on by itself during the night
possible faulty power board, although it could actually be set toi turn on at a particular time..... check in the 'menu' under timer
Dec 08, 2015 | RCA Televison & Video
Is there a reset button on rca p52939
No there is no reset button . you would unplug the set for 5 min's and this will allow a reset . . with the symptoms you give id say you have a shut down issue . the set has detected a error and is putting it into a shut down sequence to protect it self from major damage .
Oct 15, 2014 | RCA P52939 52" Rear Projection Television
My RCA tv turned off in the middle of watching it and now it wont turn back on.red light comes on and tv makes clicking sound but no picture or sound.sounds like it turns off again.
Sounds like the Horizonal Output Transistor Shorted, Also on many RCA sets the Flyback Transformer is bad to go and short the HO Transistor
Oct 09, 2010 | RCA Televison & Video
Tv turns on or off on its own
Seen the movie poltergiest? Just joking. Check the timer setting in menu.
Jun 01, 2009 | Televison & Video
My horn keeps going off in the middle of the night and wont stop until you hit the horn several times and then will wait a little while and go off again
Just voluntarily fire the alarm off yourself each nite before you go to bed. Just hit the horn alarm button and let it blow once and hit it again to stop it. If you do this each nite it won't go off in the middle of the nite.
Mar 03, 2009 | 2003 Mitsubishi Montero Sport
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
My tv turns on turns off few seconds
has capactors bad,cp150([email protected])this located on main chasis towards back in the middle
Apr 05, 2008 | RCA HD52W58 52" TV
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
Turns on and off
Best to call a service center to check it.
Sep 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen on rca tv compressed into 2 inch line in middle
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
Aug 10, 2007 | RCA 20F530T 20" TV
RCA F27242GY 27" TV Logo
161 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
