Question about D-Link DI 713p (DI-713P) Wireless Router
Please explain how to connect LinkSys D-Link wireless broadband router Model No. DI-713P with Comcast broadband modem and Dell OptiPlex 360 Desktop? I am using Windows XP-Pro. Thanks, dana
Posted by DanaAConte on
Anonymous
  • 240 Answers
What is Comcast Modem's Model?
if your modem is not a Modem Router:
here is the link where you can download the manual...Mid left of the web page.
http://support.dlink.com/products/view.asp?productid=DI-713P
if you have Modem Router?
Bridge your Dlink router by changing the IP Address of Dlink Router and connect it wired to the LAN port.
send me your email add so that I can send the instruction How to install.
Posted on Mar 20, 2009
I want to connect my xbox 360 to xbox live through my dsl-200 modem but it only has 2 ports, what do I do?
D-Link routers empower gamers to easily connect their Microsoft xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to xbox Live.
  • Click here to upgrade your firmware.
  • Click here for xbox Live setup instructions with a router.
  • For xbox Live support, please visit www.xbox.com.
  • Thumbs back!
    WIFI not working with Linksys wireless-g broadband router/Comcast
    Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
    The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
    To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
    http://www.fixya.com/support/r3559128-wireless_router_security
    Should you need further assistance, please leave me a comment.
    Router and pc configuration to connect broadband via dsl modem
    Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
    1helpful
    How do I hook up to the wireless router?
    try checking the channel number of communication
    check to see if the router has been enable on the broadcasting mode
    do check if the router has been configured for WEP or WPA
    check to see if the access is based on MAC address on the router
    finally place the connection from the modem to the router in the ports numbered 1,2,3,4 instead of the INTERNET/WAN port and try connecting
    I have a d link di-524 wont work with comcast
    how is your comcast connected to di-524?
    make sure you have wireless enabled in router config.
    type in to your web browser 192.168.0.1
    login should be admin
    password leave blank unless you have set one
    then go to wireless section and check if it's enabled etc.
    How do we get a D link air plus G-630 to connect to a linksys wireless router? Comcast cable modem, linksys router, Dell inspiron 1100 running XP.
    Install the driver of the Dlink Airplus and adapter to the computer, after that connect to the wireless network to the name was made to router.
    Note: When connecting to the wireless network find the exact wireless network name of your router.
    Connection
    Hi Susie
    With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
    Here is a video as well on it?
    http://in.youtube.com/watch?v=vSAXMO7aNzg
    http://tinyurl.com/5tqqhl
    Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
    Thank you
    Rakesh
    Dell Laptop Expert
    1helpful
    2answers
    Wireless connection
    Check the Linksys web site for the manual. Follow the directions. Linksys routers have very easy set up routines and are designed for the novice.
    2answers
    DI 624 Wireless Broadband Router
    So- Red - First of all don't rate yet. This will probably take a couple notes. So, let me make sure I've got this straight:
    AT&T
    V
    V
    Modem>>>>Linksys>>>>DLink( no status or pwr lt)
    v v
    ptr ptr
    Is this crude diagram about right? Are the ptrs wired or wireless?
    How many pcs? Wired or wireless? Getting their ip from which router? Linksys model #? Operating systems?
    Open Questions:
    See all D-Link DI 713p (DI-713P) Wireless Router Questions
    D-Link DI 713p (DI-713P) Wireless Router Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Ekse
    Mike
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
