If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
check your in take screen make sure its not plugged, look for calciumbuild up. then check your valve there should be six of them. my be damaged or weiring out and or plunged. if all looks good you'll need to check your unload-er valve. check your oil to make sure no water is in there, ok. good luck, let me know.
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there. it may be that the spring has broken too.
