Home Logo
Anonymous Posted on May 27, 2013
Uberhaus dual flush toilet keeps running
Brand new, just installed uberhaus dual flush toilets do not stop filling. Both toilets exactly the same problem
5 Related Answers
phmaddnes
phmaddnes
  • 25 Answers
  • Posted on Jul 04, 2009
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Anonymous
  • 62 Answers
  • Posted on Sep 07, 2009
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Anonymous
  • 1922 Answers
  • Posted on Oct 13, 2009
SOURCE: running toilet
your float is stuck
Colin Hagey
  • 11 Answers
  • Posted on Dec 16, 2009
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
woobie dog
woobie dog
  • 1273 Answers
  • Posted on Jan 16, 2011
SOURCE: How can we stop our
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Brand new Neptune Prague toilet doesn't flush properly and doesn't have enough suction, cloggs with toilet paper. Can be fixed or it sounds like a manufacturing defect?
Raise the level of the water. The dual flush water levels are minimal by design, but need the full flush volume of water. There should be a level line inside the tank, go about a 1/2" above.
Eco Flush. Why does it keep running?
A dual flush toilet is a fantastic option to save water and make your home more environmentally friendly. Giving you the option for a half flush or full flush at your discretion, you can lower your water consumption while still getting the job done. However, like all toilets, they can present problems that mean the toilet doesn't function as it should. One common problem in dual flush toilets is constantly running. You hear the tank constantly being filled, even when it should be finished and completely full. If your dual flush toilet is constantly running, first check for the top three problems that cause this trouble:
Flapper or Seal Trouble
The flapper or seal is often the culprit in constant running water in both normal and dual flush toilets. Over time, this rubber piece may become brittle or simply misaligned. To check it, turn off the water supply and flush the toilet to completely empty it of water. Remove any remaining water with a sponge or towel. Then, you'll need to remove the flush valve canister in order to access the seal. Once you've found the seal, check to see if there are any cracks in the seal. If there are, you'll need to replace it. Otherwise, check to see if it can be re-aligned to sit nicely in its place. Some homeowners find that applying a bit of Vaseline to the seal can renew it, making it supple and functional again for a while at least.
Debris
Sometimes the water supply isn't as clean as we think. Or, dust and dirt may be able to enter the toilet, causing the fill valve to malfunction. To check it, turn off the water supply and remove the lid from the fill valve. Then, look for any debris and remove it. You may also consider brushing out the valve with a small brush. Once you're certain it is clean, recap the valve and check if the problem has been solved.
Broken Zip Tie
The fill valve in most dual flush toilets has a zip tie to keep the base of the fill valve in place. If the fill valve isn't strongly secured, it can cause the toilet to run. Sometimes these ties wear out or break before the rest of the device does. You'll need to replace a broken zip tie with a new one if you find that it's broken. If possible, you can place two zip ties on the fill valve in order to assure that the base doesn't wobble, causing the leak. Many times these problems are easy for the average homeowner to check for and repair. In the case that you are not able to find a solution to your dual flush toilet's constant running, then you'll need to call in the help of a professional plumber. A high quality plumbing company will be able to help you troubleshoot your dual flush toilet troubles and make sure it's functioning properly again.
Apr 04, 2020 • Home
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
Uberhaus canada
Usual issue is a worn or misaligned flapper. Could also be worn parts in the fill valve.
Jul 17, 2014 • Home
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 • Home
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 • Home
1helpful
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 • Home
Our Dual-flush toilet won't fill with water after being flushed; it h=just keeps running constantly, wasting water. This also happened a year or so ago; a plumber replaced the internal; float with a newer...
It sounds like a problem with the flapper valve. You will need to puchase a new flapper valve for your brand of toilet or that matches the one currently installed. Thihs video will demonstrate what can be a simple and esy soultion:
http://www.youtube.com/watch?v=Suno4wxDNk0
Trust this is helpful. Please Vote. :)
Dec 18, 2010 • Home
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
