I love this unit.In fact, when my old one glitched out, I bought an exact replacement from Best Buy (and it's still under the extended warranty). The DVD end of it is completely shot. BestBuy cannot service it (I was told because Samsung no longer supports the device and hence parts are nonexistent). I've been in touch with Samsung and will attempt to pay for the repair myself -- if they even can service it. Does anyone have a better solution? (I'd MUCH prefer to buy a new or refurbished unit because once this unit starts to go, it goes -- and in my experience that's so even after repair.
If you wish to get some details; visit the site linked here. Pull up older posts.
SOURCE: Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
SOURCE: I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
SOURCE: touchpad
This touchpad works with the same principle of a PC keyboard or a TV remote control: pushing the touchpad makes a shortcircuit between two electrical paths.
To fix the problem you need to clean the two contact surfaces that are in the bottom of the metallic film (the label where you can see de up and down arrow) and the upper surface of the electical paths (the touchpad chip) because they are dirty and their electrical properties (conductivity in this case)are missed.
Steps to fix this problems:
1. Take off the four tiny screws (two at both sides of your mp3)
2. With a very small screwdriver take apart the back cover of your mp3. Make it gently but firmly the first time it seems hard to separate it, but the back cover do not has anything more to be retained on its position. Before totally separte the back, take notice that: A) The battery is scticked to the back cover and you need to disconnect the cable that connects it to the circuit board. Separate them carlessly will break the connector or the thin cables, it will be very difficult to repair this failure; B) there are two plastic chromed pieces at the upper side of the mp3 (the ring for the strap and a large one rectangular piece that seems to reforce the audio out plug connector. Take notice how this chromed pieces are in place in order to reinstal it again latter. They will pull down because pressure only mantanis them in position.
3. With the back cover pulled apart you can see two more identical screws to the four you retired on step 1, These screws are almos at the midle of the body of the mp3. Take off this two screws.
4. Now you can take off the front cover.
5. Once the front cover is pulled out, you can see the touchpad in it's positon, take off the plastic outher square (the one that has the marks Tun On, Forward, Backward and Return) it's easy to do so.
6. Now you can see clearly the piece that don't works: the touchpad. You need to separate it from the mp3´s body. There is a flex cable that connects the touchpad to the back of the printed circuit, on the circuit board there is a connector that secures this flex cable to the board, don't pull out ,at this moment, the cable...
7. You need to take notice that the connector has two tiny brown and rectangular plastic pieces at the left and the right of the conector. This pieces, when pulled in, secures the flex cable to the connector, and when pulled out release the pressure that secures it and you can take in or take out the flex cable. Don't try to move the secures before read ...
8. With a tiny screwdriver move out (in the same direction of the flex cable) the tiny brown and rectangular pieces no more that one or two milimeters or you can broke them and can't ever make a good electrical contact, you need to be very careful to avoid damage this plastic fragile pieces.
9. Once you move this plastic secures, you can retire the flex cable from the connector, pull out to do this.
10. Now you can retire the touch pad and put it appart of the mp3.
11. With the touchpad on your hand you can see (use a magnifier to see details) that the "metal" area where you push with your fingers to control the options of the mp3 is only a tiny label, and I can tell you that this label is sticked with adhesive to the plastic "chasis" of the touchpad.
12. On one side of the touchpad label you can pull in the tip of a tiny screwdriver in order to separate the metal label of the plastic chasis. Find it and begin to separate this label, the adhesive is not too firm, once you start to see that you can separate it without damage (believe me, is too difficult to damage the metal label by separating it) you can separate totally the label from its site.
13. Once separted the label, you can see that its bottom side has a black square, this square is electrical conductive, its surface has to be clean showing an uniform black color, if you see that has dust or anything else you need to clean it up. To do that, use a pencil´s eraser to rub up the surface. The pencil's eraser has tritured crystals that works like a light sandpaper and cleans all substances that prevents the electrical properties of this black material. Finally use ethyl alcohol or electrical contact cleaner, spray it over the black square and use a tissue to make a trully clean surface (it must have the same black color and looks glossy while you see it against a light source)
14.Now you need to clean the other electrical conductive black surface that reamains in the body of the touchpad. If you pay attention, you can see electrical paths, this paths works the same way like a keyboard or remote control to sense when you touch a key or a button. This black surface needs to be cleanead the same way you did in step 13.
15. If you make a good cleaning process that restores the electical conductivity of both surfaces, the fix is maked, you now have a Samsung´s YP-Z5 mp3 working again. You need to return all unmounted pieces to its position.
16. To mount (stick) the label over the plastic chasis of the touchpad, you don't need another glue, the same that remains in the label, incredibly is reusable. I recommend that before stick up the label mount on its position the plastic square that has the marks of Power On, Back, etc and then stick over the metal label (doing so, makes easy to align the edges).
17. Reconect the flex cable to the circuit board, secure it pull in the brown rectangular plastics of the connector to its original position.
18. Put the front cover of the mp3 on its original position.
19. Restore the two screws in the back of the circuit board, this screws needs that front cover will be on its position in orfer to tighten up.
20. Return the back cover to its position, don't forget the top plastic rectalngular and chromed protector and the ring for the strap.
21. Restore the outher four tiny screws and...
22. Ready, check your mp3. It must works now!
SOURCE: Same problem
I fixed my TV for less than $30.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. Search for the part over the internet with the part#.
I hope I shed some light on the subject for you.
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
