Cell Phones Logo
brii(: Posted on May 26, 2013
My kyocera rise mobile connection turned off 4 hrs and kept turning off and on and now it won't receive or make text or calls I even tried turning it off and back on and taking the battery out 25 mins nothings wroking Btw virgin mobile is where i got the phone
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Jul 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
4037
Points
50
This seems most like the power key is tripped and haven't back to it's own place. Try to push the button let it rebound back. Else if there is a problem about the system, please try to use Restore Factory Settings to fix it, If anything can help you, I'm very pleased.
5 Related Answers
Jalal Sordo
  • 1800 Answers
  • Posted on Jun 20, 2009
SOURCE: Beeping Phone makes when called
try to set phone on the factory defaults check the settings its always onthe bottom.
Anonymous
  • 77 Answers
  • Posted on Aug 03, 2009
SOURCE: boost mobile motorola nextel i776 has delayed texts
this was a issue with Boost Mobile which has since been fixed in most markets as of May 09
Anonymous
  • 129 Answers
  • Posted on Aug 10, 2009
SOURCE: how do I unlock/flash my virgin mobile kyocera x-tc for free?
You cant unlock / flash your XTC. Cool phone, but only works on CDMA network, not on the iDen network like Boost phones. If you want to use Boost phone service, you'll have to select one of the 1/2 dozen boost mobile phones.
Anonymous
  • Posted on Aug 20, 2009
SOURCE: oroblem with my virgin mobile phone
i have the same problem.
Anonymous
  • Posted on Sep 28, 2010
SOURCE: Why wont my Kyocera x-tc virgin mobile phone let
try erasing your inbox and outbox then turn your phone off...take the battery out for 20 seconds..put it back in and it should work
1helpful
Will not let me send picture text
Do you have MMS enabled on your device? Go into your messaging/texting settings if it has a MMS or Multimedia option, make sure it is enabled.
Also, have you tried turning it off and on again? I would try this first.
Why wont my phone turn on or get any power at all
clean battery terminals with a pencil eraser then recharge phone for about 2-3 hours..nothing happens? call 18883221122 ask for replacement phone or battery..will be free if under warranty or you will be offered a discounted replacement phone..im a customer support representative..
1helpful
Forgot 4 digit lock code on my Kyocera rise
There is no method to access the lock code from the user interface of the phone. The default lock code is usually either 0000 or the last four digits of your phone number. If you have forgotten your lock code, you need to reset the phone, however, this will wipe out everything save in the phone.
Call Virgin Mobile Support for further details. Click 'Support' at the top of this page and ask Virgin Mobile's Customer Care via phone or email. You can also click LIVE CHAT on the left side of this web page, if available.
1helpful
My lgl35g tracfone won't connect to the mobile
That means your cellular data connection is barred. Ask your operator to open it and configure your settings of your mobile.Your network operator will charge for it.
Dec 14, 2012 • Cell Phones
2helpful
2answers
How do you turn on bluetooth on kyocera qualcomm 3g cdma phone?
    • 1 Turn on your Kyocera Qualcomm pdQ by pressing and holding the "Power" button until the welcome screen is displayed. If the keypad is open, press and hold the "Power" icon located on the right hand side of the phone's screen. Repeat the process to turn the phone off.
    • 2 Install the Palm Desktop Organizer software. Connect your phone's cradle to your computer and plug in the power cord. Remove your Kyocera Qualcomm pdQ from its cradle during installation. Exit any Windows programs on your computer. Put the Palm Desktop CD into your computer's CD-ROM drive. The installation screen will appear, click the "Install" button and follow the on-screen instructions.
    • 3 Perform your first information HotSync. Click the "Palm Desktop" icon on your computer's desktop. Click the "Sharing" button in the Windows taskbar to open the HotSync Manager, then click "Local." Turn on your phone and put it in its cradle. Open the Kyocera Qualcomm keypad, tap the "Sharing" button to open the HotSync menu and select "Local Sync." Enter your username on the computer and click "OK." When the sync is complete, a "Process Complete" message will display.
    • 4 Make a call with the keypad closed. Pull up the antenna on your Kyocera Qualcomm pdQ and wait for the signal strength icon to be displayed. Use the numeric keypad to enter the phone number. Press the "Send" button to make the call and the "End" button to hang up.
    • 5 Make a call from the call history on your Kyocera Qualcomm pdQ. Press the right "Smart Key" and use the "Up" and "Down" button to scroll through your call history until the desired number is highlighted. To see more information about the number, press the left "Smart Key." Press the "Send" button to make the call and the "End" button to hang up.
1helpful
It wont send or receive picture messages but will with normal text messages
Call your Service Provider
Ask them send you the MMS settings of your mobile
They will send them to you as a text message
When you receive them save an run then turn your mobile off for 5 minutes then turn it on
Then your mobile will send and receive picture messages
3helpful
2answers
I have nokia n70 but i cannot received and sent text messages nor cannot make a call keep saying network busy. please help me this.
1. Turn the mobile phone off for a second and turn on, check if you have network signal. If still not working, try #2
2. Turn off the phone and remove the battery and sim from the phone for a couple of second. Return everything and turn on the phone. If still no network or no signal from you network provider, try #3
3. Turn off the phone and remove the battery and sim from the phone, insert the sim card to your other phone and check if you can make and receive calls and text messages.
4. Insert a your other sim card from your phone and check if you can do the same.
**With this, you can identify what needs to be repaired or replaced. (Sim card or Mobile Phone). If you cannot make and receive calls and text messages using no. 3 method, it is the sim card that has the problem and needs to be replaced. But if with #4, the phone has the problem and not the sim card. You need to contact your Service/Network Provider from technical help.
Thank you.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
