Computers & Internet Logo
jan moore Posted on May 26, 2013
Thomson DH1685P set top box
My thomson DH1685P set top box can read .MKV files but i cant hear any audio or sounds, isnt i need to upgrade my set top box?? and how?
boybawang
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 03, 2014
boybawang
Contributor
Level 1:
Answers
Questions
Helped
796
Points
Many MKV videos has DTS audio which is propietary therefore unsupported by media players. The solution is to convert the DTS audio to AC3 using a free utility called MKVtoAC3 or any other DTS to AC3 programs. Note that I have the exact Thomson model you have
1 Related Answer
Anonymous
  • 32281 Answers
  • Posted on Jun 28, 2011
SOURCE: trying to watch mkv file
Free Codecs (decoders) are available from this WEB site.
www.free-codecs.com/index.htm
tip
Converting MKV to MP4 with DTS Audio to AAC for Galaxy S II Conversion
Galaxy S II Movies Converter-MKV DTS to AAC to Samsung Galaxy S II Video Converter <br /> Samsung Galaxy S II is the sequel to the critically-acclaimed Samsung Galaxy S Android smartphone.And hope Samsung Galaxy S II able to play my mkv files.But not. The audio on mkv files is mainly DTS, the Samsung is obviously not compatible with this. <br /><br />If you want to set output audio channel option to 5.1, you should choose AC3 or AAC as audio encoder. So many people think MKV DTS to AAC or AC3 is a nightmare. No, it's not so terrible any more. Convert MKV DTS to AAC, convert MKV on Samsung Galaxy S 2 with DTS sound to AAC is so easy if you owns such a powerful <b><a href="http://canon-videoconverter.com/2011/06/convert-mkv-to-mp4-and-mkv-dts-audio-to-aac-to-samsung-galaxy-s-ii-converter/">MKV DTS to Samsung Galaxy S II Converter</a></b>, which allows to you convert any types of MKV files like MKV DTS, MKV FLAC to AC3, AAC, and still keep its good quality. <br /><br /><b>Step-by-step guide</b>: <br />Free download <b>Aunsoft <a href="http://www.aunsoft.com/video-converter/">Galaxy S 2 Video Converter</a></b>, install and run it. <br /><br />Step 1: <b>Import or add the MKV DTS files into Galaxy S 2 Video Converter</b>. <br /><br />Step 2: Please select suitable format like Android - <b><a href="http://www.aunsoft.com/video-converter/">Motorola Droid X H.264 Video (*.mp4) for your Samsung Galaxy S II</a></b> as the output format for conversion.Set Size to 800*480 pixels. (This format profile is specially designed for Droid X, but it can also use for Samsung Galaxy S II phones with perfect effect, just select it for your Samsung Galaxy S II.) <br /><img src="samsung-galaxy-s-video-converter.jpg" /> <br />Step 3: Set the output audio as AAC with Stereo.Click "Settings" to select video codec (h.264) and audio codec (AAC), audio channels (Stereo). See as follow: <br /><img src="convert-mkv-dts-to-ac3.jpg" /> <br />Step 4: Click the "Convert" button to start <b><a href="http://www.aunsoft.com/video-converter/">converting MKV to MP4 with DTS sound to AAC for Samsung Galaxy S II</a></b> . <br /><br />Quickly you will get your converted AAC files and the audio/video synch correctly and perfectly.You may interest in <b><a href="http://www.aunsoft.com/how_to_put_and_play_movie_music_on_samsung_galaxy_s_ii/">how to put and play movie and music on Samsung Galaxy S II</a></b> .
tip
How to edit and convert MKV to FLV format with proper resolution for YouTube
Why MKV to FLV?
MKV format is one of the most popular video formats and can be widely supported by media players. You may received some absorbing videos clips from your friends, which are in MKV container, or you have made a favorite movie from DVD into MKV with some free tools, now you’d like to share these videos with more people on YouTube. Here comes a problem, YouTube will not allow you to upload these MKV files, and you have to convert them to something more acceptable, like FLV, a universal format of online videos and shows. How to convert MKV to FLV? There are too many transcoding tools to choose from. For me, I would prefer an MKV converter that can cut off any parts that I do not like, divide a movie into several chapters (sometimes combine some short episodes together), add some ads or watermark to each of the chapter, and adjust the aspect ratio to 16:9. Thanks to Pavtube MKV Converter, I managed to make all of that. In the following guide I will show you how to convert a MKV file to FLV format for YouTube.
Available Software - Pavtube MKV Converter
You may learn more information about Pavtube MKV Converter, or download its free trail. Note that the trial version outputs video with watermark on the screen.
Convert MKV to FLV
1. Load MKV files
Run MKV Converter. Click ‘Add’ and browse to the MKV file(s) you would like to convert, select it and click open to load in as the picture shows below.
2. Set output format and location
Click on ‘Format’ bar and select Flash Video-> FLV (H.264 encoded). There are H.264 encoded F4V and SWF as well. If you want to combine multiple MKV files as one, simply select them in file list and tick the checkbox ‘Merge into one file’. You may click the folder icon at the opposite side of ‘Output’ to specify output location.
3. Set advanced video and audio settings
Click on ‘Settings’ button to adjust video and audio parameters including codec, aspect ratio, bit rate, frame rate, sample rate, etc. The default resolution is 320*240p (4:3), which is just all right for YouTube. If you want to apply 16:9 aspect ratio, please select 480*272p in the dropdown list of ‘Size’. For HD video file, a recommended config is 1280*720p, 1500kbps, 24fps, 44.8khz, in case that you would not give in to quality degradation.
Note:Transcoding (conversion) is a process of lossy and can not upgrade the video quality. Please set no higher resolution than the source video. You can select a file and click ‘Properties’ button under the file list to check the original resolution.
4. Arrange chapters and sections.
When a file is too big to upload, you have to divide it to multiple chapters. To select a specific section of the selected video for conversion, you could click ‘Edit’ menu, switch to ‘Trim’ tab, and input specific time point in Start and End box, and click Set button.
5. Add watermark to the video and set effect.
Switch to ‘Text Watermark’ tab, check the ‘Enable’ box, and input desired text as watermark. You may click the dots button to set font, color, and size of the text, and set the position of watermark in ‘Left’ and ‘Top’ box. To add Image or Video as watermark, you can switch to Image/ Video Watermark tab. To set contrast, brightness and saturation, please click ‘Effect’ tab. After setting, click ‘OK’ button to save settings and exit editor.
6. Convert MKV to FLV
When back to main interface, click ‘Convert’ button to start conversion. Once click this button, the ViewLog will present you all the info such as conversion progress, conversion state, elapsed and estimated conversion time, and generated and estimated conversion file size. After conversion you can click the ‘Open’ button to find the FLV files for share.
Learn more: http://www.pavtube.com/guide/trim-convert-mkv-to-flv-with-proper-resolution-for-youtube.html
on Mar 30, 2010 • Computers & Internet
2answers
Why can't I play audio on certain avi and mkv files on Mountain Lion?
Sounds like it might be a codec that is not included in the OS or the applications you have tried. Can you try VLC player? It's one of the most versatile media players around and plays almost everything that I've come across.
1helpful
2answers
Hi, my Iomega ScreenPlay play MKV files but there is no sound when i connect to HDMI cable.
This mediaplayer can't read DTS sound, only AC3.What I do is that I use AudioConverter to change the .mkv files to AC3 sound before playind them. This should solve your problem.
tip
How to convert MKV DTS to AC3 on Windows 7
Converting MKV DTS to AC3 can be troublesome. You extract the audio from MKV with an app, convert DTS to AC3 with another app, and add the new AC3 audio to the MKV files with a third one. Actually, Pavtube MKV Converter is all what you need for easy and fast conversion of MKV files. You can convert MKV DTS to AC3 or AAC audio; merge multiple MKV video clips into one file, cut off unwanted black edges; and convert MKV to versatile video formats for playback on portable players. This guide will show you how to convert MKV DTS to AC3 5.1 sound step by step. You may download demo version of Pavtube MKV Converter and try it out.
Step One. Load MKV DTS files to MKV Converter.
Once you run it, this intuitive interface will pops up, from here you click "Add" button to load MKV files to this program. Double-click on an MKV file if you’d like to preview it or take some pretty snapshots.
Step Two. Select output format and set save path
Now that MKV files are imported, the next you do is hitting the drop-down button of "Format" and select an optional format. There are customized formats for different devices and application. MKV is available in both Common Video and HD Video options. You may click the folder icon at the opposite side of "Output" and browse to a different location other than default destination folder.Moreover, if you would prefer to combine multiple MKV files as one file, you may tick the checkbox "Merge into one file" and check these files.
Step Three. Set advanced video and audio settings
Click on "Settings" button, and the following window will pop up, which enables you to adjust video and audio parameters including codec,aspect ratio, bit rate, frame rate, sample rate, etc. Here you set Audio codec as AC3, and adjust Audio sampling rate and Bit rate to fit your player. By the way, 5.1 sound is available in "Channels".
Step Four. Convert MKV DTS to AC3
So long as the former three steps are finished, you can click "Convert" button to start conversion. Once click this button, the ViewLog will present you all the info such as conversion progress, conversion state, elapsed and estimated conversion time, and generated and estimated conversion file size. There is also another option that is "Shut down computer after conversion",just check it before you go out for a walk or do something else.
1helpful
3answers
Hi i have LG 42pg20 plasma tv , it have divx built in but it cannot able to play mkv file format , but avi or mpeg play , how can i upgrade divx software in tv to divx plus . divx plus can play mkv...
you can't and DIVX is an AVI format. MKV is an entirely different encoding format. There are no TVs or DVD players that support MKV. Also you will not get a DVD player that will paly BlueRay. DVD and BluRay require 2 different lasers on the drive to read the format so your software will not allow for this through a USB or hdmi either. You have what you have and there is nothing you can do aside from using the PC the movies were pirated from and connect it to the TV.
I cant hear myself , my audio isnt working
Check for whether the Audio Driver is Working .Also check the sound and audio in the control panel (Whether it is muted or not) .Reinstall Driver If the problem persists . Reinstall OS if necessary
Microsoft Windows Sound Card Test There are also several test that can be performed from Windows. Microsoft recommends the following procedure:
"Verify that Windows can play .wav files:
  1. Click Start, point to Settings, and then click Control Panel.
  2. Double-click the Sounds icon.
  3. Under Events, click an event that has a loudspeaker icon next to it.
  4. In the Name text box, be sure that the three-letter file extension is ".wav".
  5. Under Preview, click the Play button. You should hear a sound.
If you don't hear any sounds, or if Windows is not able to play a .wav file, check to see that a sound driver is enabled:
  2. Double-click the System icon.
  3. Click the Device Manager tab.
  4. Click the plus sign next to Sound, Video And Game Controllers.
  5. If there is no Sound, Video And Game Controllers entry, or you have no sound card listed under this entry, contact the manufacturer of the computer or sound card and request help reinstalling the sound card drivers.
  6. "
2answers
LG BD350C Bluray Player won't read 1gb MKV files from USB stick
Your USB device needs to be Fat16 or Fat32 but as for reading mkv files I have the same issue. Not to mention it playing divx files in a choppy fashion.
Grand Canyon Tech
Grand Canyon Tech
