Question about Altec Lansing MX5021 Computer Speakers
Crackling sound I have an Altec Lansing Mx5021 and just recently I have been getting a crackling sound from the right speaker as soon as I turn on my speakers.I have changed wiring, switch left speaker to right input still get the crackling noise only from left speaker when switched inputs. Also when I plug in headphones to the headphone jack I get no sound from the right side. Tested the headpones on another pc and they work just fine I plugged headphones directly into the PC itself and they work just fine aswell.
    New Friend:
  • 7 Answers
Bad signals
Posted on May 26, 2013
  • Danny Cox May 26, 2013
    How can I fix the bad signals?
6ya staff
SOURCE:
Anonymous
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
Anonymous
SOURCE: My Altec Lansing Speakers aren't working
Try rolling back soundcard drivers. I had the same problem when Win XP updated my soundcard drivers.
Posted on Jan 16, 2007
Anonymous
  • 64 Answers
SOURCE: No sound from headphones connected to speaker
I may be too simple of an answer but that would happen if the headphones weren't plugged all the way in. If there is a bend in the connector and it's hitting the speaker they may not be plugged in all the way.
Posted on Mar 28, 2007
Anonymous
  • 171 Answers
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Posted on Sep 24, 2008
Anonymous
  • 10 Answers
SOURCE: Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Posted on Dec 06, 2008
Altec lansing mx5021 pls. give the 9pin wiring diagramthe the color code 9pin going to mainboard.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 11, 2015 | Altec Lansing MX5021 System
Altec lansing mx5021 wired controller not working
Sounds like you might have a wire loose at the other side of the controller. This is a easy thing to find out. Just unscrew the side screws that hold the back board to the cabinet. Don't unscrew the screws connected to the speaker wire clips unless the back doesn't come off. Just look for a disconnected wire at the controller jack then put it back. If there is no loose wire then you might have a bent female contact at the outside of the controller jack. You would have to look for this looking into the holes where you plug the cable into the controller jack. If you see a bent contact then use a thin nail of ice pick and insert it into the hole where the bent connector is to try to re open the contact so the cable can slip into it easy. Don't forget to unplug the power first.
Nov 07, 2013 | Altec Lansing MX5021 Computer Speakers
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Where can i buy these speakers?
This is the only place i can find that still stocks this old model of speakers:
http://www.buyregalo.com/products/Altec-Lansing-MX5021-%28Black%29.html
There are many places that sells the next model, but that model has been discontinued.
Jan 31, 2011 | Altec Lansing MX5021 Computer Speakers
Windows update disconnected my Altec Lansing BX2 speakers sound.What should I do?
I had a similar problem with my Altec Lansing BX2 speakers. When bringing my HP PC out of "Sleep Mode" (Windows 7), I either had a blank screen with only a cursor or a desktop with no start menu, desktop icons or any means to operate the computer. After unplugging the speakers and hard booting the computer, the PC returned to normal operation. I'm looking for a solution myself.
Aug 13, 2010 | Altec Lansing MX5021 Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Altec Lansing MX5021 Computer Speakers Logo
789 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
