Question about Schiller Medical
Auto printing problem
Ekg only prints on manual
Posted by ellak777 on
  • Electro Med Services
    Electro Med Services Mar 18, 2013
    HI, check this link for know more about schiller AT 1 Problems and solutions and setting of A1 http://electro-medical.blogspot.in/2011/...
Anonymous
    Problem Solver:
  • 13 Answers
Replaced the battery. If this action doesnt resolve the problem contact me.
www.biomedtechpr.com
[email protected]
Posted on Dec 05, 2009
2answers
When auto print is pressed the machine blanks out and nothing prints
Try this link to slide share for a colour rendition of the user manual
http://www.slideshare.net/DiscountCardiology/schiller-at-2-ekg-manual
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
2helpful
1helpful
GE MAC1000ekg not printing clearly . My EKG machine is recording the EKG well but when I print it comes out very faded.
The heat on the print head can fade over time giving you a poor print. also the feed roller can wear and give poor pressure to the print head. thw way to diagnose it is to put a peice of electrical tape on the print roller and print an ekg. if it prints well in the area where the tape was, it is the print roller. if there is no change it is the print head.
[email protected] www.overstockme.com. Jeff Watson
3helpful
The printer stop when you request to print out and in auto mode print only seconds time
check to see if the power light goes off when that happens. it sounds like the battery will need to be replaced.
3helpful
2answers
Schiller AT-1
I have a problem with ECG Schiller AT-1. In auto mode, it prints nothing but in manual mode it works properly. Could you help me solve this problem
4helpful
2answers
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
2answers
Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
SCHILLER AT 2 EKG ISN"T PRINTING ON AUTO PRINT I NEED TO KNOW HOW TO RESET IT. I'M LOOKING FOR A MANUAL.
my machine now printed 2 paper in auto print mode, i want this print one paper .Can you help me solve this problem?
[email protected]
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Medical Logo
Top Schiller Medical Experts
Mark Ultra
Tom Chichester
Are you a Schiller Medical Expert? Answer questions, earn points and help others
