1992 Dodge Dakota Logo
Anonymous Posted on May 25, 2013
Truck wont start
Getting good spark and new fuel pump. never had any problems, just all of a sudden the other morning it wouldn't start, just turns over and over but nothing. replaced distributer cap, rotor, coil, plugs, wires, and fuel pump but still nothing.
montehammons
Level 3:
  • Dodge Master 5,531 Answers
  • Posted on May 25, 2013
montehammons
Dodge Master
Level 3:
Answers
5531
Questions
Helped
1645498
Points
17401
If you have no fuel pressure at the engine when key is on, the pump is not coming on. Check fuel pump fuse, check fuel pump relay (relay should click when key turned to on-put finger lightly on it and feel for click when someone turns key to on). If no click, signal from computer may be lost, ground for relay may be lost, or relay may be bad. If it clicks, wiring from relay to pump may have failed, or the relay's main power source may not be there at relay-find the fuse link or maxi-fuse that powers that relay. One terminal at relay should be hot at all times-can check for that with a test light.
If pump is working and you do have fuel pressure, you will need to check injector circuit. Post back if questions, or need further help.
Testimonial: "i have fuel pressure and i hear the pump coming on when i turn the key. i think it may be a sensor of some kind that may tell it when to send the fuel to the injectors maybe? I push the pressure valve on top of the motor and i get a quick squirt then the fuel trickles out--don't know if that is helpful or not. Thanks for you answer."
  • montehammons Jun 02, 2013
    No such sensor-once the pump puts pressure in the lines, it means there is fuel under pressure against the injectors. If you have throttle body injection, the pressure is a little under 20 psi, so that quick squirt may be about right. You might want to put a fuel pressure gauge on that valve to be sure. If multi port injection, pressure would be a lot higher-around 40 psi. If it is TBI, you can observe the fuel spray out the bottom of injectors while the engine is cranking over. You should see a fine mist cone pattern when looking down the throat of throttle body-a friend must be cranking the engine over. If no gas coming out, you may have to diagnose the injector circuit.
  • montehammons Jun 03, 2013
    I hope you're still here, bill, or come back to this lonely place...lol. Did you find the problem? it sounds like you were close. I wish i'd caught you reply sooner...to say as always, check the fuse first, the injectors are on a fused circuit, and with a little research and a wiring diagram, pretty easy to figure out, if so inclined, lol, perhaps the majority of people don't give a rat about learning about their primary mode of opporstation...there, I made a new word. ...looking at technology from the experience side, injectors are pulsed in a crafty manner: turn key on and supply constant voltage to the injector, and wait for the computer to touch the ground wire from injector to ground. don't know the tech., but it grounds it internally. there's your pulse. easy to check with a testlight, too, both the voltage wire, and can check if computer is grounding the circuit properly as engine is being cranked over, see if the computer is working right by watching your testlight blink as engine is cranked over and your testlight lead is hooked on the positive battery post,...and you are probing the ground circuit at the injector terminal connector that you pulled off to check your injector circuit. Did I go about this backwards? lol. all questions will now be entertained, lol;/.;
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 12, 2009
SOURCE: engine cranks ,but no spark.
ain t many more parts to electrical system left... i had same problem once n it was my ignition modulator.located under distributer.**** i can t remember,i think my car would not turn overfrom that.or only other thing could be a fuse.i 'd check every fuse too .hope this might help.
Anonymous
  • Posted on Jun 19, 2009
SOURCE: 1994Dodge Dakota Wont start changed distributor
could be a bad crankshaft position sensor or a bad camshaft position sensor. Either would cause no spark. I would check to see that you have fuel coming up to the throttle body
Anonymous
  • 24 Answers
  • Posted on Jul 31, 2009
SOURCE: my 02 dodge 5.9 v8 engine turns but wont start
if it wont turns over and theres no spark it means that ur alternator is done..buy a new 1 and there ya go.,..problem solved :)
Anonymous
  • 31 Answers
  • Posted on Aug 24, 2009
SOURCE: 1995 dodge dakota 2wd 3.9 no spark to plugs,or coil,orfuelpump
First of all let's explain how the spark gets to the plugs. There is a crankshaft position sensor and a cam sensor. They are what determines when to fire the coils and injectors. The crank sensor is located on the passenger side on top of the bellhousing, the cam sensor is the pickup plate in the distributor. As the engin turns the send refernece pulses to the computer which grounds and ungrounds the ignition coil causing it to discharge and send voltager from the secondary coil wire to the center tower in the distributor cap. The rotor button recieves the voltage and distributes it to the 6 towers (1 for each cylinder) If you say you're getting spark from the rotor that tells me the primary side of the ignition system is working, and the secondary side is working into the distributor cap. I'd check for spark out of the plug wires at the plugs. Pull a wire and insert a #2 phillips screwdriver into it, hol the shaft of the screwdriver aprox 1/8"(no more) from the exaust manifold and observe the spark as someone turns over the engine. You should see a nice blue spark. If theres spark, spray a little gum cutter in the throttle body an crank it, if it fires you have a fuel problem. Install a fuel pressure gauge on the schrader valve on the fuel rail and observe it as you crank it. If theres no fuel pressure maks sure there's fuel in the tank, if so climb underneath and beat on the bottom of the tank with a rubber hammer, the pump may be going bad, sometimes you can jar them and make them run.
Anonymous
  • 713 Answers
  • Posted on Aug 26, 2009
SOURCE: engine cranks wont start
i do believe that's what it is if it will not let get a diagnostic or if it will not let you access the computer the computer is bad.
Have a 1996 ford explorer. It started the other morning just fine and ran good, that afternoon I couldn't get it to start. Changed the fuel filter and it started and ran fine again. Cut it off when I...
first need to make sure you have enough fuel pressure. Hook up a tester and check against the specs. if its too low, then your probably looking at a fuel pump. By replacing the filter, you allowed more fuel to flow. Also, make sure you are getting spark and injector pulse.
1997 SC1 wouldn't start the other morning. It wasn't getting sparks to the plugs. Its battery is good and heard the fuel pump humming. thought it was the ignition coil they were bad replaced t
Ok what you are going to have to do is called a wiggle test have someone cranking while you wiggle all the wires at the module and everywhere till it starts or tries to start and when you notice a condition for the better examine that area very well for (ANY) type of wire problems. Please rate my solution and give testimonial this is how i earn my achievements Thanks in advance
2helpful
Have a 2001 Malibu. Will turn over but wont start. Just changed spark plugs
With my 2001 Malibu it wouldn't start sometimes. Try changing the the fuel pump relay (It's in the fuse box & is less than $20 to change).
No spark and no sound from pump
as you suggested crank position sensor cause such troubles, as hard starts and sometimes stalling. simply replace it.
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
I have a 1996 Chevy Blazer 6 cylinder 4.3 Vortex engine. The check engine light has been on for a few weeks but it was running just fine. Until all of a sudden it wouldn't start last night. I had...
My first thought would be: If you repaired an emissions hose, take the car back to Auto Zone (or another parts supplier) and let them tell you what code comes up now. You eliminated one problem, now you have to find another.
I wouldn't do a fuel pump without more information.
Gary
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
2answers
2002 cavalier. Intermittently won't start. It'll be fine for a week or 2, then suddenly it won't start. When it does start it fires right up. It's got a brand new battery and alternator....
Try looking at the fuel filter, it might be partly clogged or just clogged.Locate the fuel filter, disconnect it and (I know this sounds strange) blow through it, if you get resistance of any kind, then it's bad, if it blows completely through with NO resistance at all, then it's good.
3helpful
4answers
2005 cavalier won't start
In this situation you have to determine what is the cause.... is it spark???? or is it fuel???
these are the very least of the basics any car man has to take in order to determine where he is going with this vehicle...first spray some ether into the air intake and see if she attempts to run...if yes its a fuel problem...low fuel...dirty fuel/filter clogged/fuel pump malfunction(in the Tank) or fuel pump relay defective(can you hear the pump with the key turned on??? If yes the pump and relay is Ok.
secondly pull a plug wire and ground a screw driver between the plug wire and the plug leaving an air gap about 1/4 in..... have someone crank it over.... is it snapping/sparking???? If so spark(ignition) should be ok problem is fuel.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
