Dacor ECS127 Epicure Electric Single Oven Logo
Question about Dacor ECS127 Epicure Electric Single Oven
Dacor ecs127 manual cpo130w
Reset button
1 Related Answer
Anonymous
  • 213 Answers
SOURCE: Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Posted on Nov 27, 2007
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
How do you use the self clean feature?
there is usually a button on the front display that says self cleaning
I cleaned my oven and now the elements will not
There are several possible causes of this failure. Here is an article that addresses them, although written for a GE oven it may be also be relevant to your machine:
www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Maybe this will shed some light...
Best Regards,
Bruce
1helpful
I don't know how to clean the oven
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
Dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
LED FRROZEN
Sounds like you have a need for a circuit board. First, disconnect power for a few minutes and re-power. If that doesn't fix it, get a new board. Turn off power before working on your unit.
1helpful
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
2helpful
Oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
Top Dacor Ovens Experts
Jaime Hernandez
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
