Question about Sharp EL-738 Scientific Calculator
How to calculate the square root - Sharp EL-738 Scientific Calculator
Posted by Glenys Johnson on
Nicole Sengers
    New Friend:
  • 21 Answers
To calculate square root you push 2, 2nd function, and the number you want the square root of, equals. This applies to any root you want to calculate
Posted on Jan 17, 2014
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
The square root is the second function of the "3" key. To calculate the square root of 3, press 3 2ndF 3 =
Posted on May 25, 2013
How to do square root on calculator ti 30xa
Use the square-root key, two keys above the 9 key. For example, to calculate the square root of 2, press 2 square-root =
Nov 21, 2013 | Texas Instruments TI-30XA Calculator
How to calculate a square root on HP12C
Use the square-root function. It's the g-shifted function of the y^x key, leftmost on the second row. For example, to calculate the square root of two, press 2 g square-root
Sep 21, 2013 | HP 12c Calculator
4 squre root 81
Take the fourth root. The square root, denoted by a 2 on top of the "root thing" or more commonly without a number at all, is the second root.
Usually the easiest way to calculate the fourth root is to calculate the square root of the square root. So in this case the fourth root of 81 is the square root of the square root of 81. The square root of 81 is 9, the square root of 9 is 3.
Apr 18, 2013 | Office Equipment & Supplies
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
Jan 17, 2013 | Casio FX-9860GII Graphing Calculator With...
I dont know how to find the square root on my casio fx-300ES scientific calculator problem it wont let me square root 42 , when i square root 42 , 42 keeps coming and not the answer
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Sep 07, 2011 | Casio fx-300ES Calculator
How can you use the square root key to find the square root number?
Press 2nd [square-root], enter the number, press ) =
For example, to calculate the square root of 5, press 2nd [square-root] 5 ) =
May 07, 2011 | Texas Instruments TI-30 XIIS Calculator
Have TI30xIIS calculator. How do I find square root of a number. For example, the square root of 9. Where is the square root? I know 3 is the square root of 9, but how do I do this on calculator. ...
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
Feb 16, 2011 | Texas Instruments TI-30 XIIS Calculator
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
How do i calculate square roots with this?
Use the square-root key to the left of the divide key. To calculate the square root of 4, press 4 square-root =
Nov 02, 2010 | Texas Instruments TI-30XA Calculator
I need help with square root functions
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Nov 19, 2008 | Texas Instruments TI-86 Calculator
Sharp EL-738 Scientific Calculator Logo
555 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
