Question about Metra Ford F 150 Truck 1996 Up
I have a 1996 f-150 sputters when accelerating...
My Ford F-150 (1996 manual trans. 6 cyl. 2wd, 2 gas tanks) started sputtering out today on my way to work. It was fine for about 10 min of operation the felt like it wasnt getting gas. I then left it sit for 2 hours or so when my son went to tow it home. he got in it and started it and drove most of the way home just fine until about a block away he expierienced the same thing. When i got home from work the truck wouldnt even start until i switched to the other gas tank. it ran fine then. Is there 2 seperate fuel pumps on the tanks and the one just went bad? please help...
Posted by sokbeef5 on
Anonymous
  • 58 Answers
IF U HAVE 2 DIFFERENT GAS TANKS BOTH OF THEM HAVE THERE OWN FUEL PUMPS, WHICH MEANS IT WENT BAD...........
Posted on Mar 20, 2009
What to do with sputtering and lack of acceleration
Scan for codes stored ion the OBD computer. Many auto parts stores can do this for you at no charge. Based on the results - a complete tune up may be in order.
Apr 14, 2015 | 2002 Ford Taurus
Engine sputters accelerating seems like its missing
Sounds like you need to check your filter's there is one in the tank also.
Jan 12, 2018 | 1995 Nissan Pathfinder
Sputters and dies on cold start, significant drop in gas mileage.
You need to rebuild the carburetor or clean the choke linkage and make sure the choke valve closes cold.
Nov 12, 2013 | 1985 Isuzu Pickup
1994 Ford escort 1.9L sputters
throttle position sensor or crank position sensor. but first have it on a fault diagnosis machine to find a fault code and go from there
Feb 27, 2012 | 1994 Ford Escort
2005 Ford Taurus Sputtering
stickingvalves collapsed lifters bent push rods fault ignition or damadged spark plug wires start it up at night look under the hood for sparks jumping from wires replace fauilty wires
Jun 22, 2009 | 2000 Ford Focus
Sputters on acceleration, transmisson feels like it slips
you have a torque clutch problem chan your torque transmission
Nov 18, 2017 | 2000 Ford Taurus
Distributor cap firing order 1993 chevy cheyenne truck v6
Firing order is 1-6-5-4-3-2 cyls. # 1-3-5 on drivers side front to back and cyls. # 2-4-6 passenger side front to back.
Nov 28, 2008 | 1989 Chevrolet C1500
Pressure buildup in the gas tank which causes the car to sputter and die unexpectedly.
I have never seen or heard such thing. You have a different problem. Is the "check engine light on?" Gas tanks have pressure in them on regular bases and I have never seen car sputtering because of a pressure in the gas tank.
Sep 09, 2008 | 2000 Nissan Sentra
Metra Ford F 150 Truck 1996 Up Logo
253 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
