SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
SOURCE: Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
SOURCE: kenmore dishwasher model 665
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
SOURCE: Kenmore Dishwasher Model 665 leaking from bottom of door during wash cycle
This can be due to the seal being dirty, missing, and or worn. Check for the seal and its condition
dishwasher not finishing wash cycle
