Question about Vizio L32 32 in. LCD HDTV
Mirror display can't connect mac pro to lcd hdtv..with pny
Posted by edwin on
matt martin
  • Vizio Master
  • 1,258 Answers
If your are referring to the image (reverse video, ie, every one is left handed, wording on ticket tape backwards etc.) on your TV, the problem is in the signal board. Generally unplugging and plugging in the TV will not reset the TV. Just repaired a TV with mirror image. You will need to replace the signal board. The signal board has all the rca component jacks, hdmi, audio, and the RF connection for cable or over the air signal. Thanks for asking me.
Posted on Aug 01, 2013
What are the steps to turn on mirroring on a MacBook Air?
In your display preferences, there should be a check-box that says 'Mirror Display', and that should solve your problem.
Apr 12, 2013 | Apple MacBook Air
How do i hookup my mac laptop to this tv?
Assuming you have an HDMI connection on your TV - as most do these days - you can either connect wirelessly or with wires. Here is a good guide on how to connect a mac to the tv it includes the kit you'll need to do it. Hope that helps?
May 09, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I've connected my macbook pro with a DVI-D to HDMI adapter cable. The autosource briefly detects my computer, then gives a "no signal" indicator. Meanwhile, my computer detects the display, but I have no...
It sounds like there is a conflict in the display types. the tv and the mac must be set to the same type of signal and display type. for example, your mac is set to output at 1080x640, but the tv is set to 720x480. They have to match or they will conflict each other
May 07, 2010 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
Screen shift when connecting Mac to LCD
When connected to an external display you have 2 options.
Extended you can stretch across both screens like a giant desktop or you can have mirrored displays which have exactly the same thing on each.
With your monitor plugged in...
  1. Open Apple ▸ System Preferences..
  2. Select Displays
  3. Go under Arrangement section
  4. Check the Mirror Displays check box
IF YOU LIKE WHAT I WROTE PLEASE VOTE 4 THUMBS UP!
(any less screws up our average)
Thank You and Good Luck!
Feb 04, 2010 | Apple MacBook Pro Notebook
I am trying to usa a VGA cable to watch my mac book pro on my 42" Insignia 1080P hdtv. when I do I just keep getting the message not supported on teh TV... I have changed my screen ratio on my mac book pro...
Use a 60Hz refresh rate and a basic resolution (Like 1024x768), is it works, set the resolution to the native of the display (Maybe 1920x1080 @ 60Hz).
DON'T set a refresh rate higher than 60Hz for any LCD.
Oct 27, 2009 | Insignia 42" LCD Flat-Panel HDTV
Eed help connecting MacBook Pro to Vizio VP50HDTV
I would say this is a resolution issue. The LCD on your MAC is capable of a much higher resolution than your television. To mirror your MAC you must lower the resolution to something that is at or below the televisions native resolution. The native resolution of the VP50 is 1366x768 so you will be able to do the following resolutions: 640x480, 800x600, 1024x768 and 1366x768.
Apr 04, 2009 | Vizio VP50 10A 50 in. Plasma TV
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Dell projector, Mac book Pro display problem
Hi smithmollie,
There should be a "displays" icon 67f8081.png in the top right portion of the menu bar where you can change the display mode to "Mirror Display" whenever you connect the projector.
If it's not there go to "System Preferences" > "Displays" > "Display" tab and put a checkmark next to "Show displays in menu bar".
Also you can go to "System Preferences" > "Displays" and leave it open while connecting the projector and change the settings to "Mirror Display" there.
Best regards,
Thomas
Feb 21, 2009 | Apple MacBook Pro Notebook
Electron Blue IV monitor: wrong mirror display with Mac 10.5.5
Is the mirroring still taking place or just on the one display.  If it just on the Macbook, go to the display settings and select the arrangement button, there should be a mirror button there.
Oct 11, 2008 | Computers & Internet
Vizio L32 32 in. LCD HDTV Logo
105 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
