Question about Watches
Relic watche zr11853 automatic is not working. No movement in the skeletal innards but the dial works if pulled out. There shouldn't be a "battery correct?
Hank Schadt
    New Friend:
The RELIC ZR11853 is an automatic movement (spring) you have to rotate the crown to wind the spring,
the Automatic part is, when its worn on the wrist, the movement of your arm swings a small weight in the watch that winds the spring.
Posted on Jul 07, 2017
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Relic watch 3 dial
Chances are they represent one of the following-
Month of the Year
Time of Day (military time)
Day of the Week
Day of the Month
It depends on what the dials have on them - usually there is some indicator (abbreviated months, numerical values, etc)
Posted on Mar 04, 2008
Anonymous
SOURCE: Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Posted on Apr 25, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
Anonymous
SOURCE: relic watch with animated face
anyone willing to sell theirs?
Posted on Feb 04, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Posted on Feb 10, 2009
Where to find batteries for relic watches?
Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
May 26, 2014 | Relic Wet ZR11672 Wrist Watch for Women
I have Relic VX3J 3 Eye - stopped working after 2 years.
If turning the adjustment bead does not result in a clicking then it is likely quartz. I am presuming it did not require winding. So if it clicks and comes back to life it is automatic (just wear it to charge it) if not then it is likely quartz. Most automatic watches can also be manually wound to charge. This is better for the movement when it is fully unwound, 10 full turns to be on the cautious side from flat. It is unlikely you can overwind good quality modern watches as they have a clutch to prevent over winding. cheaper watches may or may not have this feature.
Mar 22, 2014 | Relic Watches
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Baume & mercier hampton city watch
Does the dial have "Automatic" wtitten on it". If it does then it's a mechanical movement. If it has "Quartz" then it requires a battery. If the watch isn't running perhaps it just needs a battery. This may also explain why the pushers aren't working. If it's mechanical the watch needs to be wound before the pushers will work. What are the markings on the subdial.
Jul 19, 2009 | Baume Et Mercier Hampton City Leather...
How to access older timex automatic watch second hand
You should be able to open the back by popping it off with a sharp knife blade. Sometimes, the lip where you'd open it is hard to see and usually under the band, between the lugs. The movement will just come out. If I read you right, you know how to do this, once the movement is removed. You can't just pull the hands off. Hopefully, you'll be able to just VERY EASILY bend the one that is causing the problem.
Feb 15, 2009 | Timex Watches
Do as folloes:
Feb 09, 2009 | Relic 0504648FA
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
Watches Logo
548 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
