Question about Metra Ford F 150 Truck 1999
Where is the radiator drain plug for a 1999 Ford F-150?
Posted by rangers71_6 on
jdthefixer
  • 747 Answers
My drain plug is broken to the radiator on a 1999 Ford windstar.how to fix it?
get a new drain plug from a radiator shop
get a new tank for the radiator
get a new radiator
Sep 21, 2018 | Ford Cars & Trucks
Where is the radiator drain plug of ford taurus se 1999 model
bottom of radiator tank engine side of radiator
Oct 09, 2015 | Ford Cars & Trucks
Where do i find radiator drain plug
I had a 1996 Taurus. My drain plug was on the back of the radiator, by the lower hose. It was a plastic butterfly key type of top. It broke( being plastic), when I struggled to open it. I hope this helps
Dec 30, 2010 | 1999 Ford Taurus
Where is radiator drain plug on 1999 ford escort wagon?
on the rear of the radiators plastic side tank, it is easier to see it from under the car.
May 06, 2010 | 1999 Ford Escort
Were is the drain plug for the radiator on a 1999 Tarus located?
Most radiators don't have drain plugs anymore. You just remove the lower hose. Loosen the clamp and twist back and forth until it breaks free.
Apr 28, 2010 | 1999 Ford Taurus
Need to drain the radiator on my 99 ford escort.wheres the drain plug at?
Remove the bottom hose and start engine run for 30 seconds to cycle out radiator fluid.
Aug 29, 2009 | 1999 Ford Escort
Can't find engine lock plug to drain antifreeze
You'll have to drain it from the radiator or taking off the bottom radiator hose.
Jul 10, 2009 | 2005 Ford F-150
Radiator Flush Plug
under the bottom of the car on the drivers side of the radiator,,,theres a drain plug there that you have to open,,,its on the back side of the radiator
Feb 26, 2009 | 1999 Ford Taurus
RADIATOR CAP LOCATION
there isnt one. the plastic jug on driver side between headlight and air box is how you fill the radiator. there is a hose from the bottom of that jug that runs to the bottom of the radiator.
Aug 03, 2008 | 1999 Ford F150 Regular Cab
Radiator Flush Plug
look under the left end of the radiator, at the bottom. Under the "bumper", a small white plastic thumbscrew...it's a valve of sorts to drain the radiator.
Jun 13, 2008 | 1999 Ford Taurus
Metra Ford F 150 Truck 1999 Logo
289 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
